It is currently Sun Jan 21, 2018 6:31 am
 Post subject: turbo 1.3 buggy
PostPosted: Sat Nov 14, 2015 3:41 am
hi. I want to turbo my subaru justy engine ,it is a g13ba engine 9.5:1 compression . I need 130-160 hp .I am thinking to use a kkk k03 turbine from 1.4 tsi . I need power from low rpm not much hp at high rpm because it's a car for off road . I want to use the engine stock ( if this is the best option ) and turbo at 7-9 psi.
I need some advise about this project .
-what adjustment are required.
- if there are turbo's that fits better to my project
- also I need help with the electronic sistem
- what injectors to use ( if it is necessary to change the stock injectors)
(this engine is used on swift/samurai )
