It is currently Fri Feb 23, 2018 5:02 am
 Post subject: MK4 Geo Metro GTi turbo.
PostPosted: Tue Dec 15, 2015 8:06 am
I couldn't resist. I'm gonna try and do a turbo conversion on the metro GTi. 8)
With the experience from my '89 gti turbo, I'm gonna try and do this as cheap as possible.
This is the car.
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Tue Dec 15, 2015 8:34 am
Turbo will be a TD04HL-15G. It's from a volvo. The inlet flange on the turbine side is strange; it's a modified T3.
The turbo also has a built in BOV, which should come in handy later.
After a few research on this turbo, the "H" in the TD04HL stands for high flow. Which means the turbine side is a bit bigger. I see the last number on the housing as a "7". I think that's the 7cm2. Whereas on the td04l-13t on my gti it has a 6cm2 exhaust side.
I'm gonna try and rebuild the turbo also.
Turbo exhaust manifold will be homemade by a friend.
Started already taking out the AC stuff and making room for the intercooler.
The bumper grill is cut out. I also took a bit from the bumper from the inside to make room for the intercooler between the lower chassis bar and bumper. I think I took 1.5" off.
Intercooler has an inlet / outlet of 2". Really cheap on ebay. (CXracing)
Test fitting the intercooler.
2003-EVO7 GT-A
