It is currently Fri Oct 20, 2017 9:04 pm
PostPosted: Tue Feb 26, 2002 12:14 am
Allrighty all,<br><br>Looking through my factory shop manuals I see that the 90-97 1.3 is a 8 valve setup, the 98-01 is 16 valve. Are they the same block with just a different head, or am I smoking crack and misreading things??? Makes no sence to me <br><br>Loki <p></p><i></i>
PostPosted: Tue Feb 26, 2002 9:00 am
The only difference would be in the head. The internals of the 16V would probably be a bit stronger too. <p></p><i></i>
 Post subject: And...
PostPosted: Wed Feb 27, 2002 1:49 am
And definitely more weight balanced (lucky for the turbo guys). <p></p><i></i>
 Post subject: Re: And...
PostPosted: Wed Feb 27, 2002 1:45 pm
So the bottom end is the same?? Intresting <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> May have to look into getting the 16v head. <p></p><i></i>
PostPosted: Wed Mar 20, 2002 12:15 pm
You woudl be better off getting the gti dohc head. <p></p><i></i>
PostPosted: Wed Mar 20, 2002 7:26 pm
But don't forget you'll need another computer if you change from SOHC to a DOHC... <p></p><i></i>
PostPosted: Mon Mar 25, 2002 10:56 pm
the 1998 16 valves only gives 78 Hp instead of 70 for the 89-97 8 valves so I don't think it's worthed <p>Never underestimate the power of a suzuki. you could be surprised...</p><i></i>
