It is currently Sat Oct 21, 2017 1:35 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
PostPosted: Wed Jul 30, 2003 5:58 pm
number one!
I'm doing the same swap as you actually, 1.0 auto - 1.3 8v manual (doing this in a convertible though). I'm only a step or so behind you in this process, appreciate the effort of you documenting the whole process. Looking forward to updates on your site <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br><br>~ Chris <p></p><i></i>
PostPosted: Fri Aug 01, 2003 9:16 am
The mad quebecer
The mad quebecer
Ok, basically all the swift-metro-sprint-firefly frames have the same mounting plate inside the frame, however the threads for the motor mounts from a 1.3 dohc or sohc are hiden behind a layer of sheet metal. No more bullshit about having a custum bracket, frame mods or other horror story, all you have to do is to pick a small hole saw and to remove a small chunk of sheet metal, that's it!<br><br><!--EZCODE LINK START--><a href="http://ca.f1.pg.photos.yahoo.com/bc/jardamuth/vwp?.dir=/Gt+Convertible&.src=ph&.dnm=Hole+Uncovered.jpg&.view=t&.done=http%3a//ca.f1.pg.photos.yahoo.com/bc/jardamuth/lst%3f%26.dir=/Gt%2bConvertible%26.src=ph%26.view=t" target="top">See example</a><!--EZCODE LINK END--><br><br>However, depending of the year/ model, the holes that hold the motor mount cover to the frame might be missing from the mounting plate. The holes I'm talking about are those that surround the main tranny mount on the frame. On a turbo3 frame they are there, on my convertible they weren't, on a swiftg gs they are there and so on. I didn't bothered with those as I carefully bolted the main srew with the cover into place and then secured it with 3 self-drilling screw teks. <br>Once again, the cover's threads are not alway there but the main 10mm threads are there on any suzuki model car.<br><br>Good luck with your swaps and have fun! <p>Jardamuth<br><br></p><i></i>
PostPosted: Fri Aug 01, 2003 10:47 pm
Good to know. I guess it's time to break out the sawzall and get the auto mount out of the way. <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <p>--------------------<br><!--EZCODE LINK START--><a href="http://www.geocities.com/gasolinefumes/index.html"><!--EZCODE BOLD START--><strong>My Website</strong><!--EZCODE BOLD END--></a><!--EZCODE LINK END--></p><i></i>
PostPosted: Tue May 08, 2007 10:01 am
Someone in this thread mentioned that when going from a 1.0l to a 1.3l SOHC 8v that you didn't need to swap the harness. I just want to validate the accuracy of this statement. I'm planning on doing this very swap and have seen information stating both sides of the field: Swap in 1.3 harness vs. Use 1.0 harness.
Can anyone confirm that they have done this swap without swapping the harness?
Thanks,
Bob
-Bob
PostPosted: Wed May 09, 2007 5:42 am
Thanks,
Bob
I put a 1.3L SOHC 8V in place of the 1.0L in my '94 Metro. At first I was just going to use the 1.3L engine harness, but it wouldn't plug into the main harness without splicing in a different connector. It might have been because my Metro was an auto. Then the same thing happened with the dash harness. So I ended up using almost all of the wiring from the donor car. It was easier for me since I had it all right there and the car was gutted anyway.
But if you don't have the harnesses or don't want to pull the whole car apart, using the 1.0L wiring might make the most sense. If you're sticking with a similar age engine, the 1.3L ECU will plug into the 1.0L harness. 1989-91 and 1992-94 engines use different ECU plugs.
You will need to make a few changes to use the 1.0L harness. I think the ignition is set up a little different.
1992 Swift - Parts car (gone)
1991 Swift - Parts car (gone)
1990 Swift - Parts car
1997 Metro - Parts car (gone)
1993 Metro - Parts car
1989 Swift GTi - Parts car
1998 Metro - Parts car
PostPosted: Thu May 10, 2007 8:04 am
Very, very cool. I've got both cars 92 vert and 94 sedan... Planning on swapping the engines so the 'vert has the 4cyl and the sedan has the 3cyl (need to bump up the torque a bit). If the harnesses between the two are largely interchangeable that will save me heaps and heaps of work. Thanks Gasoline Fumes... if anyone else can corraborate or has done this before, please let me know. Electrical is the most difficult part of mechanic work for me, so I want to gather as much info as possible.
Thanks,
Bob
-Bob
