It is currently Wed Feb 21, 2018 2:33 pm
 Post subject: 76mm forged pistons?
PostPosted: Sat Feb 04, 2006 12:23 pm
I am looking for 76mm high compression pistons. Can someone help me where to get them for good price? I am looking for compression around 12,5:1
Thank you
Lander
Suzuki Swift Kit Car
PostPosted: Sat Feb 04, 2006 1:01 pm
I can get you 75mm & 75.5mm maybe 76mm not sure.
76mm needs sleeves in a 1.3 block.
PostPosted: Sun Feb 05, 2006 6:04 am
I think that 76mm is maximum what is possible with stock sleeves.
You are able to get that 76mm forged pistons, high compression? Brand? Weight? Pics? Price?
Lander
PostPosted: Sun Feb 05, 2006 4:33 pm
The mad quebecer
The mad quebecer
24.5 x 3 = hardest maths evar! :lol:
PostPosted: Sun Feb 05, 2006 8:05 pm
Apparently harder than that, it's 25.4 x 3
PostPosted: Mon Feb 06, 2006 12:07 am
For pistons like that you may have to get them custom made. I had some forged aluminum ones made by Wiseco, I was happy with the product. Look them up they can make whatever size you want. 76mm sounds like you may crack a sleeve or toss a rod if you are not carful. For 3 pistons and rings from Wiseco cost $350 USD. That should give you a rough idea of price. Good luck
DAn
PostPosted: Mon Feb 06, 2006 1:25 am
Mama Said Knock You Out!
I've got a block with 75mm 11.5:1 forged aluminum pistons ready to go ;) fully rebuilt and ready to rock too! *hijack*
TGstring wrote:
sooooo clean it's duuuuurrty.
PostPosted: Mon Feb 06, 2006 3:27 am
DAn
That is very good price. Where to get wiseco pistons for that good price??? Nice will be 76mm and 12.5:1 compression. Do you have pics of pistons? Weight?
Lander
PostPosted: Tue Feb 07, 2006 12:39 am
Here are the piston specs from Wiseco on the build sheet.
Bore Size: 2.9520" @ suggested clearance of .0030"
Piston gram weight at inspection: 261.5-262.0
Wiseco is in Mentor Ohio (440) 951-6600. They make very good high proformance stuff.
For $350USD it came with pistons, wrist pins and pin retainers.
For your GTI motor they can cut the valve pockets where ever you want and you tell them what size and compression you want. They may need more info about other things. Give them a call or look for them on the web.
Here are some pics.
Dan
PostPosted: Tue Feb 07, 2006 4:36 am
Here are some pics.
Dan
Thank you soo much for infos.
So that price dont include pistons rings?
I am from Czech republic, EU, for me it is hard to have call in english...
Lander
PostPosted: Tue Feb 07, 2006 4:20 pm
Sorry I forgot to mention it does include piston rings... lates night post :wink:
Dan
PostPosted: Fri Feb 10, 2006 7:47 am
I'm working on same project just like you.
I try to put 76mm piston in my g13b DOHC.
I wonder to put daihatsu charade 1300 16v piston but with modification in the top off it. the Dc 16v piston is 3mm higher, we must chop it to put on.
Other option that people in my country do is use Honda D13 piston, but still to chop the top around 2mm. default dia 75mm, we can use oversize 1.
For best value we could try Dc 1300 16v piston, price <$100 included ring.
Please comment..
PostPosted: Fri Feb 10, 2006 12:15 pm
25.406mm per inch.
I'm going to suggest a cheaper way of seeing what the manufacturer has in stock and then boring the block to fit those pistons. the Honda D-series came stock with 75mm pistons, so some nice performance pistons for that engine could fit well depending on your application. I know JE-pistons makes D-series honda pistons in standard sizes and then upper sizes in 1/4 mm increments. (75.0, 75.25, 75.5....etc.). So you could check that out.
just a suggestion. Hope you find something good :)
PostPosted: Tue Oct 03, 2006 7:23 am
try bike pistons many are already forged.
CBR1000RR are 75mm but oversizes are available.
d.
