It is currently Tue Oct 17, 2017 12:30 pm
PostPosted: Wed Mar 01, 2006 11:59 am
I took the engine out of my vitara last weekend, replaced a conrod and put it back in. The rods don't like 19psi much when hitting the overboost limiter that doesn't have hysteresis. One of the rods was bent like a banana... I'll put in a picture of the rod when i get around it.
Now, I'm backing the boost down to 15psi for a good safety margin.
PostPosted: Wed Mar 01, 2006 10:44 pm
The mad quebecer
The mad quebecer
Jesus, look at this!! This is what your viking ancestors probably looked like when they arrived in newfoundland. I can't help but picture yourself with a axe and a sword yelling: EEeeyaaAAaa!!!!! :shock:
Well, I bet you can't beat the rod I bent this winter! :razz:
PostPosted: Thu Mar 02, 2006 6:50 pm
Oh yeah? I think I have beaten it :lol:
PostPosted: Thu Mar 02, 2006 7:47 pm
The mad quebecer
The mad quebecer
:shock:
You cheat! That rod has been bent with a press! :lol:
Well, those rods are unbelievable! honestly, I don't think a honda rod would bent that much without breaking out.
PostPosted: Thu Mar 02, 2006 9:47 pm
Senior Member
the things people do to get more cubic capacity.....
PostPosted: Fri Mar 03, 2006 4:06 am
CAN I ASK SOMETHING TO G16B CAN I PUT RODS FROM A HONDA IS IT BETTER FROM THE STOCKONE (SUZUKI)? FROM WHICH MODEL OF HONDA
PostPosted: Fri Mar 03, 2006 4:18 am
Indeed, they are not made from cast iron. It's not a very hard steel either.
PostPosted: Fri Mar 03, 2006 4:48 am
nice rod :shock:
I dream to live forever
But live to die tomorrow
PostPosted: Fri Mar 03, 2006 11:01 pm
The mad quebecer
The mad quebecer
Those are the rods in my 2005 echo HB. I don't think they'll support lot of boost. What d'ya think? :lol:
PostPosted: Fri Mar 03, 2006 11:48 pm
What's an echo HB? :huh:
PostPosted: Sat Mar 04, 2006 12:07 am
Echo hatch = Vitz = Yaris
Image[/quote]
PostPosted: Sat Mar 04, 2006 7:41 am
Ah, the Yaris...
I nearly rolled one 2004 Yaris because it's antilock brakes were so awful. I threw it into a corner while on the brakes, as soon as the rear left wheel went off the ground the brakes were cut and I went a helluva lot faster through the corner than I intended to.
PostPosted: Sat Mar 04, 2006 3:15 pm
The mad quebecer
The mad quebecer
My car is set up for lapping with B&G springs + koni yellows and 16" wheels with P-zero tires. It handle surprisingly well.
PostPosted: Fri Sep 29, 2006 9:06 pm
http://www.suzuki.co.jp/dom4/motor/96/autohill.htm
400hp g16b!!!! :shock: :shock:
