It is currently Sat Feb 17, 2018 8:34 pm
PostPosted: Mon Apr 10, 2006 11:18 am
For anyone interested, I've just stripped down a G16 from a 1998 Esteem, and weighed the major components. My measurements are as follows:
Block – bare with main caps, water pump 48.5 lbs
& oil filter
Cylinder head with valve train (less camshaft 25.5
but includes caps)
Pistons & rods (no caps), head gasket, head bolts, 8.5
cam tensioner, misc bolts
Crankshaft with front pulley bolt 25.5
Camshaft with gear 6.5
Oil pan & valve cover 8.25
Oil pump, rear seal/cover, thermostat housing, 9.0
Front pulley, oil pick up, flywheel boss, misc bolts
Total 131.75 lbs
I didn't weigh the intake manifold (that looks similar in size to the SSGT one), exhaust manifold (heavy looking cast item) or flywheel/clutch assembly (this one is an automatic, but I suspect this should weigh same as SSGT).
Cheers
Yosh
'90 SSGT
'89 Mazda 323 GTX
'87 Saab 900 SPG
'79 Lancia Zagato
'70 TVR Vixen
PostPosted: Mon Apr 10, 2006 1:27 pm
Bill, is that from the car in A-1, and whats your plan...?
 Post subject: Esteem Engine Weighed
PostPosted: Tue Apr 11, 2006 8:56 am
Mike,
No this is a motor that came out of a 98 Wagon at Tate's. They had bought the wagon as a non-runner and swapped in the motor from wrecked 2000 that's at Cathcart.
The no. 4 rod had seized at the big end and bent the rod. I'll likely keep the block, head, intake and pan (like new). Camshaft is not distributor-type. Not sure about motor from A1......high miles, but it did run well. If it looks better than the one from John's, I'll build it up. Otherwise, it'll donate missing bits.
P.S. The 5-speed tranny on the Esteem 1.6 looks identical to Swift 5-speed (it's even cable clutch/rod shift). Also, Esteem 1.6 block is externally identical to 4-cylinder Swift.
Yosh
'90 SSGT
'89 Mazda 323 GTX
'87 Saab 900 SPG
'79 Lancia Zagato
'70 TVR Vixen
PostPosted: Tue Apr 11, 2006 9:12 am
You might want to take a tape measure to the bolt pattern.
I'll take that cam if you don't decide to use it. :D
PostPosted: Wed Oct 04, 2006 11:39 pm
awesome featherweight!!!! maybe lightest mass produced 1.6 in the world!!!
with alloy pulley you can knock off another 3lbs off thats 58kg all up!!!
PostPosted: Thu Sep 10, 2009 2:15 am
I weighed everything in my G13BA 1298cc when I built it in '07.
The complete engine as you might expect to be lifting it out (with manifolds, carburetor, air cleaner, alternator, clutch, radiator hoses and oil but no starter motor) is 85.558kg.
The file was originally in Excel but has since been saved in OpenOffice so let me know if anybody has trouble with it.
G13BA_Engine_Weight.xls [95.5 KIB]
Downloaded 242 times
http://www.youtube.com/user/ausgixxerpilot
http://s236.photobucket.com/albums/ff70/ausgixxerpilot/
http://www.putfile.com/ausgixxerpilot
