It is currently Tue Oct 17, 2017 8:03 pm
 Post subject: G16b Project
PostPosted: Tue Nov 07, 2006 5:40 am
Hi guys,
Building a g16a block with g13b head, On a site i saw that they recommend you use a 1.8 vitara head gasket to make the car more drivable and to lower the compression to 10:1, also to use a smaller diameter on your tensioner so you have more flexibility when choosing a belt, is this all true?
Some questions.. What crank pulley to use, are the g13b and g16a crank pulleys the same?? What alternator to use? What starter to use? What flywheel to use? can i use the g13b flywheel (i'm fitting the g13b gearbox)
I heard someone say that this conversion g16a block g13b head and g13b gearbox pulled all the way to 7500 RPM puts down a time of 14,3 sec on the 1/4 mile, can this be true?? How much horsepower and torque does this conversion have(STOCK)??
Thanks Jason
PostPosted: Tue Nov 07, 2006 2:11 pm
:search:
EngineWhisperer wrote:
v-tec ain't $hit honda sucks and b16-18 are like tampons every pu$$y needs one.
PostPosted: Tue Nov 07, 2006 4:58 pm
Hmmmm.....een nederlander, kijk eens op mijn site :wink:
