It is currently Mon Oct 16, 2017 5:38 pm
 Post subject: 1.6 vitara bottom end
PostPosted: Tue Nov 07, 2006 6:43 pm
Hi ive got a swift gti 1990 and ive heard that i could put a 1.6 vitara bottom end on with no problems is this true and if i can what modifications need to be done and can i use the gti gearbox and flywheel.thanks
PostPosted: Tue Nov 07, 2006 7:06 pm
Start searching the board. Theses topics are all over. Try looking in the right areas too.
PostPosted: Tue Nov 07, 2006 7:08 pm
Well, you can use the vitara bottom end but you won't be able to rev as high as the g13b.
For the gearbox to fit you'll have to build some type of adapter plate.
More info can be found in the proper section.
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Tue Nov 07, 2006 7:10 pm
wow, it's already been moved to the proper section. :lol:
2003-EVO7 GT-A
PostPosted: Tue Nov 07, 2006 7:31 pm
thanks lads your help is apreciated.il leave it then.just wondering if i was to fit the world racing intake manifold from suzukird would it be better to upgade my injectors aswell.thanks
