It is currently Sat Oct 21, 2017 1:35 pm
PostPosted: Thu Nov 30, 2006 7:35 pm
Hi guys,
Building a 1.6 block with the gti head and gti gearbox, i was wondering what power and torque i could expect with these mods?
- cold air intake with k&n filter
- 52 mm throttle body
- 8,5 plug wires
- msd 2 blaster coil
- aluminium underdrive pulley
- headers
- 60 mm no cat exhaust system
- dnx muffler
I did quite so research on this conversion, i is been said that stock could give you 120 hp and lots of torque, and i read in a topic that stock 1.6 converion with gti gearbox could run 14,3 sec on the 1/4 mile sprint, please help me on this.
Thanks..
PostPosted: Thu Nov 30, 2006 8:04 pm
banned
if you build it...numbers will come
CURSE MY ENEMIES FOREVER LETS SLIT OUR WRISTS AND BURN DOWN SOMETHING BEAUTIFUL.
PostPosted: Thu Nov 30, 2006 9:22 pm
What throttle body are you using and where did you get the under drive pulley? The stock 1.6L makes about 95HP and 100 LB/Ft torque.
PostPosted: Thu Nov 30, 2006 9:23 pm
banned
PostPosted: Thu Nov 30, 2006 9:35 pm
The stock throttle-body-injected, SOHC G16A generates 133Nm of torque at 4000 rpm - versus the GTi's 108Nm at 5500...
The throttle body is an original throttle body bored to 52 mm, the aluminiun single pulley is from http://www.suzukird.com
Most people doing this conversion forget that they have to use a smaller tensioner and the gti crank pulley and a 1.8 vitara head gasket to lower compression to 10:1. most people use the 1.3 or the 1.6 gasket, dont know why...
PostPosted: Thu Nov 30, 2006 9:55 pm
I'd assume that a G16A/G13B hybrid engine - depending on its compression ratio - should generate around 95kW with an exhaust and intake, correct me if i'm wrong
