It is currently Fri Oct 20, 2017 3:36 pm
 Post subject: 2.0 Vitara swap
PostPosted: Mon Dec 04, 2006 10:05 am
anyone done it or seen it done?
a kit is available from http://www.trailtough.com that would make it a bolt in swap as far as the trans goes....
height would most likely be an issue, but you could always fab a bubble into the hood.....
just curious.....
PostPosted: Mon Dec 04, 2006 10:07 am
as far as building mounts goes, the mounts are very close to the same location as the stock mounts on the block (from what i have read)....so you could just bolt the engine to the trans and bolt the trans into the car....then build the mounts for the engine......
