It is currently Thu Oct 19, 2017 6:28 pm
PostPosted: Tue Jan 16, 2007 8:45 am
who done this before???
the motor seems pretty much the same but more power and extra cilinder and 10 valves more.
they look much identical.
can i use my gti clutch and fly along with my gear box????
any more differences???
thanks folks in advanced!!!!!
PostPosted: Wed Jan 17, 2007 4:34 am
Please search and read some more as it has been covered many times, yes the engine will fit but along with needing new drive shafts there are a whole heap of little things to sort out, ie cambelt end engine mount is slightly different than a g13b/g16b chassis, top holes on your gearbox won't line up correctly but can be made to fit etc... not to mention the wiring :lol:
PostPosted: Wed Jan 17, 2007 8:50 am
Swift 1.0, search out some of my old posts. I have replaced my G10T with a G13BB 16 valve engine...and turbo of course....
The trans from my Mark 1 Turbo bolts up to the engine perfectly, but as posted above, the axles and trans mounts need to be used from a 4 cylinder car...reading my past posts will detail the changes needed.
Darcy
PostPosted: Wed Jan 17, 2007 9:11 am
ok guys thanks for your replies.
i´ll look for your posts mr. pipe :wink:
