It is currently Tue Oct 17, 2017 6:41 pm
 Post subject: G16A injector flow rate
PostPosted: Thu May 10, 2007 7:58 am
Does enyone have the standard Vitara injector flow rate handy?
They are Hi-impedance and are marked
INP-470
PostPosted: Thu May 10, 2007 9:50 pm
Hi there,
I "assume" the Vitara injector would be the same as the one in a 1.6 Baleno (G16B).
The OEM Baleno injectors are a 250cc/min item.
Green injector.
Denso Brand. (refer to attached link to picture)
http://www.redlinegti.com/forum/vth.22915.injectors.htm
On my Baleno (with Turbo and Wolf V500 ECU) I have fitted the injectors from a MY03 Impreza WRX which are a direct plug in replacement for the original 250cc items.
The WRX ones are blue and are Denso brand also.
In the Baleno with standard fuel pressure and standard injectors you run out of pulse width by 7psi.
PostPosted: Thu May 10, 2007 10:32 pm
Thanks for the info.
PostPosted: Thu May 10, 2007 11:14 pm
itsdamo wrote:
Hi there,
Green injector.
yes it is a Vitara injector. It has a beige head though...
PostPosted: Sat May 12, 2007 10:07 pm
fede
PostPosted: Sun May 13, 2007 12:38 am
Thanks fede.
straight into the bin with the 4 of them.
PostPosted: Sun May 13, 2007 5:00 pm
I'm using a set of injectors from a mazda 2.2l. turbo
I pick them up at the junker they are 13.7 ohm 326cc/min
PostPosted: Wed Jun 04, 2008 5:00 am
Just an FYI, I found out some info about the stock injectors (the model is INP-470 as tekkie mentioned in the first post). According to this page the stock injectors are manufactured by Nikki and flow 172cc @ 3 bar. From what I have read/seen so far it looks like Nikki injectors use a Denso (ND/NipponDenso) connector (round type).
