It is currently Sun Jan 21, 2018 2:14 am
 Post subject: g16b
PostPosted: Fri Jul 20, 2007 12:53 pm
alright people i was wondering to make a g16b could i use the 1.6 bottom end off of a vitara or does it have to be a swift 1.6 i will be using the gti box obviousley head etc was just wonderning if there the same
steve :D
p.s do not care about crank cons or pistons as they will get changed before the engine is assambled
www.uk-ssgti.com
PostPosted: Sun Jul 22, 2007 4:29 pm
I think you're best bet is to use the search option as this has been covered before in quite good depth I believe.
The answer is yes you can use the vitara bottom end. You may need an adaptor plate to fit you're G13b gearbox but don't quote me on that as I can't quite recall.
alex
PostPosted: Mon Jul 23, 2007 4:32 am
The problem you will find if your doing a g16 conversion is your car will lose its revy feel, however if you just want a larger engine for your swift why not go with a J series engine? ill see how much a j20 from a vitara will cost or j18 from a gsr baleno will, this afternoon as im heading down to dacar suzuki
PostPosted: Mon Jul 30, 2007 11:28 am
cheers guys thanks for that as well prab
steve
www.uk-ssgti.com
