It is currently Wed Oct 18, 2017 9:32 pm
PostPosted: Mon Jan 21, 2008 8:07 pm
Does anybody knows wich is the RPM limit the valve springs on a 16valve sohc head?
thanks
fede
PostPosted: Tue Jan 22, 2008 11:28 pm
Another question:
Did the dohc and sohc heads came with the same valve springs??
fede
PostPosted: Wed Jan 23, 2008 1:33 am
The springs on the 16V SOHC head are small, and fairly light.
The good thing is that the valves are too.
While it is not a high RPM screamer like the GTi, it is capable of some extendeed RPM action.
Keeping the lift, and RPM reasonable (under 9mm lift, and 8000RPM) is the best bet.
PostPosted: Sun Feb 10, 2008 9:13 am
redline is where its at for the 90mm stroke, beyond that expect possible valve float.
Although easily capable of going beyond the redline, expect rod bolts to escape also.
PostPosted: Tue Feb 12, 2008 7:41 am
What is the difference that makes posible to rev a D16 higher than mine g16? I don´t think D16 rods are longer than g16 ones.
what do you think?
fede
