It is currently Tue Oct 17, 2017 6:36 pm
PostPosted: Tue Mar 04, 2008 8:54 pm
Hello,
Does anyone have any info on ARP bolts for the G16B SOHC engine?
I am particularly after main and head bolts / or stud kits if available.
One would imagine that with everything they have something on their shelves even if intended for another type of car or motor say Honda may suit the G16B???
Has anyone done it? Any info would be appreciated.
Failing that I will send them some sample bolts to make stronger ones.
90-92 = 69 Alfa Romeo 1750 Berlina
92-94 = 80 Toyota T-18 SE
94-95 = 94 Suzuki Swift GTi
95-96 = 95 Suzuki Baleno GS2
96-01 = 96 Suzuki Baleno GTX
01-02 = 01 Peugeot 206 GTi
02-04 = 02 Peugeot 307 HDi
04+ = 00 Suzuki Baleno GL TURBO
PostPosted: Wed Mar 05, 2008 1:01 am
I have a set of head studs in my G16B in my Sidekick from http://www.occracing.com/ also http://www.suzukird.com sell studs but it doesn't specify G13 or G16 and I don't know if there the same.
PostPosted: Thu Mar 13, 2008 8:27 pm
OEM 2000 Model Baleno G16B Engine Bolt Info
Head Bolts
Quantity: 10
Size M10-1.5 X 95
Head: 10mm AF, 12 point
Thread Length: 34mm from bottom of bolt
Washer: Captive Flat 2mm thick, 17mm OD.
Head Bolt Holes in Block
Total Depth in Block: 41mm from deck to bottom
Thread Depth in Block: 35mm which starts ~6mm below deck
Head Bolt Holes in Head
Top of Head: 10.4mm OD.
Bottom of Head: 13mm OD.
Head Thickness (with reference to head bolt mounting): 61.5mm
Bolt Head / Washer Area Available on Head: Exactly 17mm OD as per OEM Bolt Washer
Main Bolts
Quantity: 10
Size: M10-1.5 X 70
Head: 14mm AF Hex
Thread Length: 32mm from bottom of bolt
Washer: Captive Flat 2mm thick, 19mm OD.
Main Caps
Cap Height: 45.0mm
Cap Width: 22.0mm
Hole Size: 10.4mm OD.
Bolt Head / Washer Area Available on Cap: 19mm as per OEM Bolt Washer
Main Bolt Holes in Block
Total Depth in Block: 34.6mm from deck to bottom
Thread Depth in Block: 24mm which starts ~4mm below deck.
Flywheel to Crankshaft Bolts
Quantity: 6
Size: M10-1.25 X 18.5
Head: 17mm AF Hex
Thread Depth: 18.5mm
Washer: None
Pressure Plate to Flywheel Bolts
Quantity: 6
Size: M8-1.25 x 16.5
Head: 12mm AF Hex
Thread Depth: 12mm from bottom of bolt - (No thread on top 4.5mm where captive washer sits)
Washer: Captive Spring 1.2mm thick, 13mm OD.
I have emailed the above info to ARP so I will see what they say... They may be able to match it up to something exisiting... if not I will have specials made.
Pictures of the OEM Bolts are here:
http://www.untubbed.com/pics/thumbnails.php?album=99
Cheers,
Damian
PostPosted: Fri Mar 14, 2008 11:07 am
I used ARP 165-5401 which is either for a Nissan or a Saturn(invoice says Saturn, a google search says Nissan) on my G13B. The washers were wrong tho. Too large to fit in the recesses on the head, so I had to get different ones.
PostPosted: Sun Mar 23, 2008 5:03 am
what bolts do i have to use if i wanna put a G13B head onto the G16B?
PostPosted: Thu Mar 27, 2008 6:10 pm
OK, ARP have the following studs available off the shelf in 8740 series that will suit the G16B SOHC requirements.
Torque specs of these studs exceed the OEM bolts.
You can get tougher in ARP2000 spec but they will have to be custom made at more time and more cost.
So I plan to order these.
Part numbers:
AM4.500-1UB
(4.500” stud, with .958” of M10x1.5 and 1.047” of M10x1.25, undercut
(Shank diameter; for the head stud )
AM3.750-1LB
(3.750” stud, with 1” of M10x1.5 and 1” of M10X1.25, no undercut mains)
These are what I plan to order... they are also looking into off the shelf flywheel and pressure plate bolts to match OEM specs for me.
PostPosted: Tue Apr 01, 2008 8:17 pm
OK, the part numbers quoted above are only for the studs. (No nuts or washers)
I have been quoted the following prices from Rocket Industries. (Who I have to order ARP bits through in Oz)
Qty: 10 of AM4.500-1UB $10 + GST each.
Qty: 10 of AM3.750-1LB $7 + GST each.
Special Order from the USA.
The kit part numbers which include studs, nuts and washers are as follows: (These are prices from Rocket industries in AUS$)
KIT # 201-4603 = $245.30 EACH AND CONTAINS 14-STUDS / NUTS & WASHERS.
KIT # 201-5001 = $124.11 EACH AND CONTAINS 10-STUDS /NUTS & WASHERS
Unfortunately one of them presumably main stud kit includes 14 when only 10 are needed. Extra cost. Ergh! The kit must have been for a six cylinder car.
The above kits have been ordered through Rocket Industries.
Cheers,
Damian
PostPosted: Fri Apr 25, 2008 11:51 pm
Hello,
I picked up the ARP Main and Head studs from Rocket Industries this morning.
Damn Expensive in the end ~$430 for both main and head stud kits but I guess that is the way it goes. :|
They are kits to suit a M50 BMW 2.5 6 Cylinder.
KIT # 201-4603 = HEAD STUD KIT
KIT # 201-5001 is superseded by KIT # 201-5000 = MAIN STUD KIT
Thus I have 14 of each item when I only need 10.
I may buy more kits a later stage and sell them off so as to get rid of the excess if there is interest.
The supplied washers both main and head washers are too big for the head... So I will have to reuse the originals.
However, the washers for the head studs which are larger than the ones for the main studs seem better suited to the main caps.
The photos are here.
Cheers,
Damian
PostPosted: Wed Apr 30, 2008 9:53 pm
My flywheel has returned after having helicoils fitted and I was finally able to take measurements that were needed to send off to ARP in regards to supplying suitable flywheel to crankshaft bolts and pressure plate to flywheel bolts.
They replied with the following:
HI DAMIAN
THE FLYWHEEL I COME UP WITH .873 UNDER HEAD LENGTH. KIT # 209-2801 = .985 UNDER HEAD LENGTH YOU SHOULD BE ABLE TO MAKE THAT WORK. PRESSURE PLATE BOLT I COME UP WITH .511/13MM. I HAVE 5-PACKS WITH WASHERS THAT ARE 16MM. USING THE WASHER WITH THE BOLT THIS SHOULD WORK. PART # 661-1017 X 2
THANKS
RONF
Thus I have emailed Rocket Industries to ask for prices...
QTY 1. - KIT # 209-2801
QTY. 2 – KIT # 661-1017
I will order them and keep them for later (next time gearbox needs to come off) and fit them then... I don't want to wait anymore and motor is going back together and into car tomorrow / this weekend.
The block returns from being bored, decked, welch plugs fitted etc today.
Cheers,
Damian
PostPosted: Thu May 01, 2008 2:44 pm
Hi will all those bolts work for the G13B DOHC or just the G16?
PostPosted: Thu May 01, 2008 8:58 pm
I am led to believe from what I was told on redilnegti.com that they are the same for the G13B but as I don't have one etc... I can not guarantee it.
