It is currently Fri Oct 20, 2017 1:48 pm
PostPosted: Sun Mar 23, 2008 5:17 am
OK readin on suzuki4u About the honda piston conversion and very interested to do this on the rally car!
Got All info on the Pistons:-
Just in case anyone else is thinking of this in the future, then full costings from Mizumoauto are:
Timing belt kit: $20.76
Engine bearings: $78.00 (2x mains, 2x B/E, all @ 0.25)
Piston set: $72.94 (0.5 oversize, so 75.5mm bore)
Subtotal: $171.70
Shipping cost with USPS EMS is $75.95 (that's airmail, takes 4-6 days)
Total: $247.65.
At todays exchange rate that's £124.50.
Bearings are ACL, an Australian company, just for comparison, I'd pay nearly £80 here for both sets of bearings inc VAT, and that's Trade.
I intend to buy this lot of Mizumoauto (Thanks IAN)
Is this all i need !
Also considering my head is already skimmed to raise compression unsure what it is at tho!!!!! And I intend on usein carbs and buyin a High lift cam * where would the power ATF be about any Ideas !
*Also with these different pistons what is MAX lift from the shafts I can use!!!
Also Also lol What is the Exsact name of thoses pistons so i know when I am ordering!!
Ross
Flat To The Mat
PostPosted: Sun Mar 23, 2008 10:12 am
It's 1351, not 1361 =)
PostPosted: Tue Mar 25, 2008 6:12 pm
OK but did I pick this up wrong or will this work in the G13B Engine!
Need to know some info!
Compression what is it and is it to high
Valve/Head clearangce
Also best place to buy?
Is 75.5 the right rebore for the liners
and any other helpfull tips would be good
Thanks
Flat To The Mat
PostPosted: Mon Apr 14, 2008 2:31 pm
This is exactly my next plan.
D16z6 honda pistons, the compresion with this change will increase to 205-210psi by cylinder.
Overhead ported 220-230psi.
And lower piston compresion to 200-210psi using racing camshaft.
I already had the nissan SR20 trotlle body.
Perform the fuel with a walbro fuel pump.
Hyundai Elandra inyectors from 1.8cc engine
the connectors are plug -n- play.
As an experiment use the MAF from SR20.
And manage the fuel/radio with a piggy back.
Two of my friends already has the modification of the pistons and the overhead ported with a bronze´s clutch and they results are 115whp Dyna tested I wipld like to improve it with the trotlle, the inyectors the pump and the piggy back.
Regards,
TicoBiker
PostPosted: Sat Jun 28, 2008 1:13 pm
high compression pistons =less fuel =more power =Hyundai Elandra inyectors garbadge
suzuki 1.3 turbo 15 psi= 301hp
http://www.youtube.com/watch?v=gppoxlEy ... ture=inbox
http://swiftgti.14.forumer.com/index.ph ... 53cd37742c
http://www.facebook.com/#!/SuzukiSwiftGtiPortugal
PostPosted: Wed Jul 16, 2008 4:22 pm
SO, what is your recomendation dude?
