It is currently Tue Oct 17, 2017 7:48 pm
PostPosted: Thu Jun 05, 2008 9:17 am
It is possible to use motorcycle pistons in a car?
if they fit and have the right compression of course.
PostPosted: Fri Jun 06, 2008 9:53 am
I have heard people talk about doing it, but never actually seen it done. I can't really see why not, although they are typically much lighter weights which can create issues.
PostPosted: Fri Jun 06, 2008 3:44 pm
I just bought some 4agze toyota rods that are heavierthan gti rods so lighter pistons maybe can compensate a little.
Also I'm in the search for motorcycle pistons specs...
PostPosted: Fri Jun 06, 2008 8:06 pm
Found some suzuki motorcycle specs:
A list with some usual bores on suzuki motorcycles. note that for the same engine there are more than one bore, possibly the smallet is standart and the ohter ones overbore
File comment: A list with some usual bores on suzuki motorcycles. note that for the same engine there are more than one bore, possibly the smallet is standart and the ohter ones overbore
suzukipistonsBORE.pdf [56.46 KIB]
Downloaded 228 times
Last edited by luizdiefenbach on Sun Dec 14, 2008 10:54 am, edited 1 time in total.
PostPosted: Sun Oct 05, 2008 6:10 pm
Seen it done. It works fine.
PostPosted: Sat Dec 13, 2008 1:50 pm
there is a honda xr ( dont quote me but i think it was an 88 400 ?? ) i saw with very similar piston specs, i think i saw it on the wiseco site. how ever they are hellishley expensive, 250+ a piston ( NZD ) as opposed to $60 for a whole set :P
PostPosted: Mon Jan 26, 2009 6:46 pm
One thing to beware of is that the skirt on the bike piston may not be deep enough for use in an engine with a much longer stroke.
PostPosted: Wed Jan 28, 2009 9:28 pm
Hey guys,
I had G13B 5 years ago using Yamaha V-Max pistons in my ice racing car.
Now, in my Swift GT daily driver, which I also use for track days, I have Kawasaki ZX-11 76mm pistons. I run this engine for more than 1 year. With a lot of other mods (stroked crank, bigger valves with 5 angles, 50mm TB, aggressive cams... A lot of torque! :twisted: I love it.
Philippe
PostPosted: Wed Mar 04, 2009 9:18 am
can i get some more info on this which you are talking about?
im looking seriously into putting in low comp pistons that are very strong. im interested in larger pin size for added strength and where it is closer to the top of the piston that a stronger and maybe longer rod can be unsed.
thanks, clauce B
wish i had a car like runbag, wonder if he would help me build 1?
PostPosted: Sat Mar 07, 2009 12:15 pm
thanks, clauce B
Custom made? Wiseco?
PostPosted: Tue Mar 10, 2009 11:37 am
thanks, ill have to look into that. the other problem is that i dont know the specs. im interested in making about 300whp, what would i be looking for in terms of piston and rods specs?
