It is currently Thu Oct 19, 2017 7:47 am
PostPosted: Sat Jun 14, 2008 4:39 am
Hi,
I'm driving a '92 Suzuki GTi. I manage to get hold of a G15A lower block. I'm going to do a G15A conversion. I would like to know which GTi parts can be used on the G15A block. The water pump, gasket, clutch, flywheel, crankpulley? I did a search but couldn't find any answers. Most of them are G16 conversion. Any help will be greatly appreciated.
Thanks.
PostPosted: Thu Jul 31, 2008 2:33 pm
freak2demon wrote:
Hi,
Thanks.
out of time check your pm
PostPosted: Mon Sep 08, 2008 7:01 pm
Superman can you please share your info with us?
PostPosted: Tue Sep 09, 2008 3:36 pm
hi
i would like to have some information about the G15 engine mainly the main bearing diameter and crank pin diameter
PostPosted: Wed Sep 10, 2008 4:08 pm
guys i just saw this post willin to share just ask a i will let u know what i know i was busy with stuff thats y i havent got back to u *broke a cam today sort it out an get back to u
PostPosted: Thu Sep 11, 2008 6:09 am
hi super man. i would like to know the main journal and crank pin diameters for the G15 so that i check out if a honda D15 crank could be used since i cant go over 1560cc turbo in order to compete in local hillclimb
regards
tim
PostPosted: Wed Mar 04, 2009 9:28 am
well im here having the same concerns. first, i was told that the SOHC g15a head has larger and straighter ports than the DOHC gti g13b head. i opted for the full 1500 engine because the closed deck is said to be a stronger design than the open deck of the gti. as it relates to the honda crank, if that was possible, there would be alot more after market options available in rod and piston selections.
it is my intention to do this conversion also, in the mean time i am swapping the head so i boost it.
(my car was initially carb)
freak2demon wrote:
Hi,
Thanks.
i see u beat me to it? :D
wish i had a car like runbag, wonder if he would help me build 1?
PostPosted: Sat Aug 14, 2010 10:33 am
Need info on G15a
M running G15s in my MK1 5 door
mods
light weight flywheel
2 inch piping
after market air intake
so far is good enough to win from a d15vtec 95 civic....but i need more power
can Gti head be replaced with the g15 sohc head....
and which piston to use to maintain high compresion.....
any help of mods on this engine
1.5 G15a MK1 Suzuki
PostPosted: Tue Sep 14, 2010 10:44 am
rozzzzz wrote:
Need info on G15a
mods
2 inch piping
all "G' series head and block are interchangeable, they are direct bolt ons AFAIK.
the SOHC G15 head bolts directly to the G13B bottom end. the GTI DOHC can also directly bolt onto the G15 and onto the regular carb G13b. as i said, all interchangeable.
id like if u could do a dyno run wt the GTI head on then a second when u change to the G15 head, not so much the HP output im interested in but the area under the curve and the torque output.
im also doing some conversions and comparisons to see how the graph looks.
