It is currently Tue Jan 16, 2018 10:29 am
PostPosted: Tue Jul 01, 2008 11:07 am
Hallo,
Any body can help with this topic?
This is distributor less engine. Signal rotor have two "pickup points".
I need to know how this points need to be located if engine is in "zero" position.
By "zero" position I understand, marks on camshaft and crankshaft are line up with marks on engine block and valve cover.
Like for timing belt replacement.
regards
PostPosted: Tue Jul 01, 2008 11:14 am
you would align the timing marks like any other timing belt replacement...
the lolcar family
PostPosted: Tue Jul 01, 2008 11:31 am
I did. This portion is perfect.
I need to know position of signal rotor.
Any body have pictures of this?
PostPosted: Tue Jul 01, 2008 6:55 pm
OK, please forgive me if I did anything wrong with attachments.
So pictures Timing_1.jpg and Timing_2.jpg are showing in my opinion correct timing setup.
This picture is only for clarification and making sure we are on the same page.
I did checked, piston 1 and 4 are up.
But take look at signal rotor. Picture T-Camshaft_3.jpg I think this two (things) should be on opposite side.
On the top of everything valves on cylinder 4 are closed. (the rocker are loose)
Help!
File comment: Is this correct cylinder order.
(not firing order)
PostPosted: Tue Jul 01, 2008 7:31 pm
im not very familiar with those motors, I havent seen ones without a simple timing mark, do you have a haynes manual or anything for the 1.6?
the lolcar family
PostPosted: Tue Jul 01, 2008 7:59 pm
I have purchased access to Suzuki online manual.
All marks are in right place.
Info about "pips" on signal rotor is not displayed any where.
I'm in dead end.
PostPosted: Tue Jul 01, 2008 8:31 pm
Bozo the crying clown
it should only be able to be installed in one orientation. unless you have removed the 'pips' wheel from the shaft.
Matt
Megasquirt Specialist.
www.mtmotorsport.ca
