It is currently Wed Oct 18, 2017 1:50 pm
PostPosted: Sat Nov 08, 2008 12:28 pm
hi there,
i have some questions.
we have an 1.3 suzuki swift from 1997
and an suzuki swift 1.6 from 1990
what do i have to do so that the engine of an 1990 1.6 will fit in the swift1.3 from 1997???
ow and the 1990 engine is an automatic.
greetz swift-girl
PostPosted: Tue Nov 11, 2008 1:37 am
Have you found your information yet? I have never done this swap, but this is some general knowledge that pertains to it. The 1.6 will NOT bolt to your 1.3 trans without fabrication work. I believe this alone is one of the major hurdles to this swap. If i were to tackle it i would want a complete donor car. Ideally it would be best if the cars were of the same generation, which unfortunately yours aren't. This is due to differences in wire harness locations. Do some digging and you will find much more information, but know that it will be a bit of a tricky swap. Just a suggestion, a 98-99 1.3 16V engine would be an easier swap and they do make pretty good power.
PostPosted: Thu Nov 13, 2008 5:15 pm
hi,
no i haven't found information yet about the swap.
the reason why i asked it.
is because whe have these cars and an 1.3 16V isn't builded since 1996 the GTI version.
and whe have an sedan 1.6 and an 1.3 hatch and the 1.6 is using much gasoline in comparing to the 1.3 engine.
PostPosted: Fri Nov 14, 2008 1:04 am
I can help, but are you going to do the swap? Are you swapping the trans also. Give me more info. It's not that hard, you just need to know what parts to use.
PostPosted: Fri Dec 12, 2008 3:26 am
Littlemsg, I gather you have some 1.3-1.6 swap info? Could I pick your brain on a possible swap I am going to tackle?
PostPosted: Mon Jan 26, 2009 5:35 am
i'm sorry that i haven't responsing you're question.
whe selled the 1.6 sedan and whe have now an 1.3 suzuki swift hatchback from 1997
it isn't that big but it sure is cheaper
