It is currently Fri Oct 20, 2017 11:01 pm
 Post subject: 1.6 ECU question...
PostPosted: Wed Dec 24, 2008 11:06 am
Don't know if this should be posted here, but here goes.
I have a 1.6 conversion on my samurai on the way (G16A). Because of some working on the head and different pistons (aprox 10.5/1 comp ratio) I am wondering how I could fool the ECU if needed.
There is no MAF sensor, so my understanding is the ECU uses the MAP sensor to calculate air/fuel volumes.(???)
If it turns out that the engine needs more air or more fuel how can I cope with that? (other than swapping the injector perhaps?)
Any suggestions?
thanks,
Stratis
 Post subject: Re: 1.6 ECU question...
PostPosted: Wed Dec 24, 2008 11:18 am
With head work, and higher compression, it shouldn't matter, unless the headwork included a high performance cam with signifigant lift and or duration.
PostPosted: Fri Dec 26, 2008 9:06 am
Thanks for the answer suprf1y.
No the cam is stock. I want the engine to be able to work well throughout the range. Didn't want something that only works in low or high rpm. It's an everyday driver and offroad truck.
However, if It turns out that some tampering is needed, what do you think is the best way?
PostPosted: Wed Jan 07, 2009 5:54 am
Sry for the OT, but can someone tell me the difference between MAF and MAP...? :oops:
I searched a 'lil, but didn't find my answer...
......................................................................Suzy.....
PostPosted: Wed Jan 07, 2009 8:03 am
http://en.wikipedia.org/wiki/MAP_sensor
http://en.wikipedia.org/wiki/Mass_flow_sensor
hope this helps
PostPosted: Mon Jan 26, 2009 6:44 pm
You will in fact need to alter the fuelling and spark timing for optimum power. It may run fine otherwise but it won't make full power on factory map.
PostPosted: Tue Jan 27, 2009 4:18 am
Baldurg,
can you elaborate on that?
To change timing I will need a programmable ecu (like Jacobs, MSD 6al-2 or the like) right?
As for fuelling, more fuel, less fuel...what do you think?
I do hope this will not mean visiting a dyno to check for best results...?!
Thanks
PostPosted: Wed Jan 28, 2009 1:23 pm
You will need a programmable ECU or a chip for your existing ECU. For small changes, a piggyback unit will do the job. You may need to add or reduce fuel (factory maps are often too rich, the purpose is to keep the cat converter from overheating)
and add or reduce spark timing.
PostPosted: Wed Jan 28, 2009 3:16 pm
Like I said.
You shouldn't need to do anything, if all you did was increase your compression.
PostPosted: Mon Mar 16, 2009 9:03 am
Yes it's preety much just comp ratio.
Thank you for the answers. I will try to keep you posted on the results. (only problem is that I won't be able to compare to the stock engine, because I had the 1.3 engine before and finding a truck with the exact same gearing, tires and stock 1.6 is not easy...I could dyno it though?!)
