It is currently Fri Oct 20, 2017 3:12 pm
 Post subject: Cam Timing
PostPosted: Sun Jan 18, 2009 4:30 pm
I have a 16v 1600 SOHC, I plan on skimming the head thus retarding the timing. I have heard that using the E slot (as opposed to the I slot) on the cam wheel advances the timing, does anyone know by how much?
Tim
 Post subject: Re: Cam Timing
PostPosted: Mon Jan 19, 2009 4:17 pm
Search?
4 degrees
PostPosted: Mon Jan 19, 2009 4:50 pm
Thanks
Tim
PostPosted: Mon Jan 19, 2009 5:51 pm
How much are you machining from the head? Does anybody remember how much it retards the valve timing when resufacing the head? :lol:
PostPosted: Wed Jan 21, 2009 3:26 pm
I followed your advice & searched using different criteria than I had previously. It was stated 1/2 a degree for each 10 thou off the head.
I have not decided on how much to skim, I need to run on pump fuel so CR cannot be too silly, using premium unleaded will help.
My plan is to decide on maximum safe CR (will be between 10 & 10.5:1) & then skim the head to suit this.
Tim
