It is currently Mon Feb 19, 2018 12:54 am
PostPosted: Thu Nov 19, 2009 3:36 pm
16 valve SOHC camshaft specs
Superfly...i've checked cam specs on Esteem 1.6, and Swift 1.3 16 valve SOHC engines, and found them to be almost identical. You've said the 1.6 tracker/Geo (truck) engine has a different cam, do you recall how different it is?
Darcy
PostPosted: Thu Nov 19, 2009 7:48 pm
For comparison, stock profiles are
Lift/Duration at .050"
85-87 1.0/3cyl 330L /192D
89-01 1.0/3cyl 330 /198
GT Int 295L/192D Ex295L /198D
Cultus In 305/L192 Ex305/D198
1.3 8V 330L/192D
1.3 16V SOHC (98-01) 308L/184D Ex 308/189
1.6 8V 356L/202D
1.6 16V (truck/sedan)In 308L/192D Ex308L/198D
What are you up to now?
PostPosted: Thu Nov 19, 2009 8:44 pm
I'm just gathering parts for further testing, and wondering if i should grab the cam from a truck engine before it's too cold to go outside....Brrrr, Winterpeg!
I will probably post a lot of dyno results of Turbo Suzuki engine testing starting in January.
Darcy
PostPosted: Fri Nov 20, 2009 8:31 am
Stop fooling around and put a real cam in that thing.
PostPosted: Fri Nov 20, 2009 11:24 pm
I have a few different versions of real cams...all for the twin cam head...and for the moment, i'm having some single cam fun! ...yes, it'd be nice to have a better cam for the SOHC too, and know that you're more than up to the task, but i've put such huge effort into a real twin cam project, that i can't justify spending a lot on the single cam, just to put it in the corner as a spare.
PostPosted: Tue Nov 24, 2009 10:40 pm
let me know how that truck cam works out for you.
trucks have a distributor drive gear on the back instead of the trigger for the CMP.
PostPosted: Sun Dec 27, 2009 5:14 pm
So, for more low end vacuum, for throttle response and pulling power, for a 1993 Tracker G16A, I should source a G13A cam?
Distributor that would be compatible with that would be....?
Can said cam and distributor be utilized w/removing the existing low mile head?
Going to premium gasoline is no problem, that might be the only downside I can see. (cyl Press)
I'm new here, and new to the brand, but I do know what I am doing in a general sense of modding and cam specs.
PostPosted: Sun Dec 27, 2009 5:16 pm
who does regrinds for G16a's? Looking for more lift, less dur. (Yeah, I'm weird...lol)
PostPosted: Thu Dec 31, 2009 6:41 pm
id like 2 know also.
8)
PostPosted: Thu Dec 31, 2009 7:10 pm
viewtopic.php?f=17&t=21867&p=168348#p168348
PostPosted: Tue Jan 05, 2010 3:29 pm
Is the reground camshaft for the G13B (distributor type) and G16B (distributorless type) the same one?
PostPosted: Tue Jan 05, 2010 5:40 pm
I generally grind the same profiles on both of them.
PostPosted: Tue Jan 05, 2010 9:44 pm
What I meant is, can a cam from a G13B head be used in a G16B head? Does it require any modifications to be made given that the G16B is distributorless? In India I have heard some tuners say that the end bit of the cam that houses the connection to the distributorless type can be swapped from the G13B's to the G16B's and can be used on the Baleno. Wanted to know if such a thing is possible or not.
PostPosted: Tue Jan 05, 2010 10:22 pm
If the G16 is dist-less, then they are the same cam.
PostPosted: Wed Jan 06, 2010 5:09 am
Yes the G16B we get here is Distributorless type. Whereas the G13B we get in India is distributor type. So was wondering how they could use a cam from a distributor type engine and use the same on a distributorless type setup.
PostPosted: Wed Jan 06, 2010 8:22 am
You can't do it without a lot of work.
PostPosted: Sun Oct 14, 2012 5:23 pm
Yes I know its an old thread....
But does anyone know the rocker ratio on the sohc 16v 1.6 ?
PostPosted: Sun Oct 14, 2012 6:55 pm
Give or take, about 1.5. The numbers listed are gross lift, so the lobe dimensions would be the lift divided by 1.5.
PostPosted: Mon Oct 15, 2012 5:47 am
Thank you. Just to clarify, this wouldnt apply to both ex and in though would it ?
PostPosted: Mon Oct 15, 2012 11:23 am
Why not?
