It is currently Fri Oct 20, 2017 2:13 am
PostPosted: Fri Oct 03, 2008 4:11 pm
Hi guys
Sorry for my english :)
I have my suzuki samurai with G13 engine and not so far ago I've bought 1.6L G16A SOHC TBI for swap.
But the all I have is: G16A block, 16V head, TBI intake, swift ECU. No harness no information about sensors and vacuum tubes.
Can you help me?
I need wiring diagram, and some manuals to this engine. I tried to search your website but my english is not the best and here is a HUGE coupe if information.
Does my ECU fit to this engine, the number of ECU is 33920-72C1
Thanks.
Alexey
Ukraine
PostPosted: Tue Oct 07, 2008 3:33 pm
Guys, I really need your help :roll:
PostPosted: Wed Oct 08, 2008 11:52 am
You need to spend some time, and search.
PostPosted: Wed Oct 08, 2008 4:21 pm
I've spent a lot of time but it's very difficult to find info when your native language is Ukrainian not English.
Anytime thanks for an answer -now I know that info I need is here.
PostPosted: Mon Nov 17, 2008 12:45 pm
Guys, returning to my previous ask for help - I really missed my head in these tons of info on your forum but still found no answers on my question.
May be you can tell me how can I my "right" search?
thanks
PostPosted: Sat Jan 10, 2009 2:04 pm
can I install sidekick (vitara) cam into the my swift's head and use my old distributor from 1.3L 8V samurai's head?
thanks
PostPosted: Sat Jan 17, 2009 2:58 pm
Today I had found the answer on my previous post by myself :?
You know guys in my country it is very hard to find suzuki vitara or swift and just impossible to find any manual for suzuki engines.
BTW I can't use my disti from 1.3 8v with vitara 1.6 16V cam, because the distributors' cases are different :|
I decided to try to find used vitara's 1.6 16V head and use vitara's disty on my swift's head.
thanks
PostPosted: Sat Jan 31, 2009 4:01 am
I need valve adjusting information for 1.6 16V SOHC head (with TBI). Where can I get it?
PostPosted: Sat Jan 31, 2009 10:37 am
Note: When checking valve clearance, insert thickness gauge between camshaft and cam-riding face of rocker arms
cold
intake .005 to .007"
exhaust .009 to .011"
hot
.007 to .009
.011 to .013
PostPosted: Wed Feb 22, 2012 2:03 am
Hi guys
need some help. I'm looking for the crank beraing set and the connection rod bearing set for my G16A.
I need part numbers and may be advice where to buy nice parts.
PostPosted: Wed Oct 03, 2012 12:50 pm
Hello,
I'm in the same situation: 1.6 16v sohc TBI from 1992 swift AWD, and not find a wiring diagram for it. Searching but nothing found.
Any help?
Thank you.
Later edit:
I've found schematics scanned somewere in Australia. Nice guys.
If somebody wants, let me know.
1992 Samurai, 1.6 16v, rear locker, 5.12 r&p, 31", double cardan, high steer setup, mercedes power steering, yj springs with missing links, DT8000 shocks, wrangler fender flares fiberglass copies, custom front bumper with Tabor winch, T-max underhood air compressor.
