It is currently Fri Jan 19, 2018 5:17 am
 Post subject: engine question
PostPosted: Mon Jun 14, 2010 4:13 pm
hi im new to the forum and have a couple of questions to ask i own a Suzuki vitara and i want to build a more powerful engine for it i was thinking of using the swift gti head and the 1.6 16v bottom end from the vitara does any1 know if they fit together or work is needed to do this thanks also im buying a swift gti next week so im sure there will be alot more questions asked from me on that as im looking to tune it right up and turbo it thanks
 Post subject: Re: engine question
PostPosted: Tue Jun 15, 2010 2:58 am
You should search a bit...
There are already many topic regarding this conversion and few good tutorials on how to do it...
......................................................................Suzy.....
PostPosted: Fri Jun 25, 2010 10:35 pm
I saw one today for the first time up close, looks like the same head as my 1.3, and the water pump and block castings appear the same.....if I could find the injectors Id swap mine to a 1.6. Too bad they dont make a 1.8 you could throw in there.
2001 Swift 4/5, 3.52 trans, AC, Power Steering, 16580r13s
1993 Mitsubishi Galant 2.0 16 valve auto
1990 Mitsubishi Eclipse GS 2nd Gen 2.4 DOHC 4G64 10.5:1 pistons, 2.25 catback, 160CHP
