It is currently Sun Jan 21, 2018 5:44 am
 Post subject: 1.6L DOHC by Suzuki?
PostPosted: Tue Aug 16, 2005 2:48 pm
Hey people,
Just a quick question, does anyone know where I can get a 1.6L DOHC engine from Suzuki and wether or not it can be TurboCharged? I want to turn my 1997 Swift into a sleeper, cause people always make fun of me for what i am driving, im gonna light a fire under their a$$ hopefully soon!
1993 Toyota Pickup "The SupraTruck", 7M-GTE Swap
1990 Suzuki Swift GT
PostPosted: Tue Aug 16, 2005 8:13 pm
The 1.6 came out of the sedans, it's a 16 valve SOHC engine. If want a DOHC engine you'll have to make a hybrid with a GTi head.
PostPosted: Tue Aug 23, 2005 2:17 pm
...or modify a 1.5L 16v Ignis engine.
PostPosted: Tue Aug 23, 2005 3:46 pm
i wonder does that make a huge different?
PostPosted: Sun Sep 04, 2005 7:39 am
When you say Sedans, do you know the name(s) of the cars? So if I call the Junk yard I might sound like I know what I am talking about when I tell them I am looking for a 1.6L.
Thanks Steve
PostPosted: Sun Sep 04, 2005 8:10 am
Thanks Steve
It was the Swift sedan, but they were never available in the US, so you likely won't find one.
PostPosted: Sun Sep 04, 2005 9:04 am
Were there ever any 1.6L offered in the US? If Not looks like I go for the 1.3 DOHC
Thanks Steve
PostPosted: Sun Sep 04, 2005 12:24 pm
Isn't it basically the same engine that was used in the 1.6 Vitaras and perhaps the Tracker variant?
PostPosted: Fri Sep 23, 2005 8:29 pm
Whoa Whoa hold the phone Suzuki came out with a 1.6 liter in thier X-90 2 seater SUV in the late 1990's you could try and transplant tha motor out of one of those
PostPosted: Fri Sep 23, 2005 9:36 pm
It's a standard SOHC though..
PostPosted: Sat Sep 24, 2005 1:29 am
Also the 1.6 doesn't have the forged internals like the DOHC G13B does.
PostPosted: Sat Sep 24, 2005 8:30 am
As far as forged parts are concerned, its only the crank thats not forged in the 1.6, and a forged crank is not really that important, especially in small bore 4cylinders. Neither have forged pistons, but both have forged rods.
I forgot about the tracker/X90 motor. It is actually better than the sedan motor because it has the multiport fuel injection, and would probably work OK in a hatch.
PostPosted: Sat Sep 24, 2005 9:32 pm
None of the 1.6 motors have forged anything. The rods are VERY thin and have a HIGH ratio vs. the nice forged DOHC 1.3 motor..
PostPosted: Sun Sep 25, 2005 9:42 am
For $4000Cnd you can build a bullet proof bottom end with forged internals and a custom crank....
There's no replacement for displacement ;)
PostPosted: Wed Jan 11, 2006 9:38 pm
i have a 94 swift with a 1.6 SOHC out of a sedan anyboby know the horse power on a stock one and any body hear of putting a bigger intake on it of the trackers
PostPosted: Thu Jan 12, 2006 2:51 am
if you really want a good 1.6L, just get a 4AGE 20V Black top engine from a toyota ae111.
 Post subject: g16b
PostPosted: Thu Jan 12, 2006 12:28 pm
i have used g16b from baleno with the head of gti i tuned up the crack with 57mm pistons better quality and with mecanicals valves with cams. i put the engine up to the car the left mounts it's ok but the muddle mount sems to turn the engine to the right. i have not put the gear box yet up. does anyone know if i am going to have problem with the mounts. i believe that i have to reconstruct the muddle mount. i am going to used the gearbox from 1.6 will that fit ok?
PostPosted: Wed Jan 18, 2006 1:36 pm
how about the 1.8 DOHC motor from the suzuki esteem wagon i beleive the people in the states have them in there sedans also. anyone fimiliar with this motor does it look to big for the swift? cause there are alot of them in the junkyards down here. also i think they put out 125ponies and tourque in the same range.
PostPosted: Thu Jan 19, 2006 4:23 am
I think that the J18A engine fits into a swift, that's as big as you can go.
It puts out 99kW at 6,500rpm, with 157Nm of torque at 3,000rpm.
PostPosted: Sun Jan 22, 2006 1:28 pm
Such a misleading quote. In many cases you can destroke an engine, reduce it's displacement and make more power because you can rev higher.
Plus, whoever came up with that quote originally obviously didn't know forced induction.
Displacement is nothing without boost!
PostPosted: Tue May 16, 2006 3:29 pm
I have the 1.6 SOHC and it's a slow as hell :)
 Post subject: .
PostPosted: Tue May 16, 2006 4:58 pm
Senior Member
The X90 is just a Vitara/Tracker/Sidekick whatever with a different shell. Running gear and chassis are all the same.
I'm STILL yet to see a G16 running faster numbers than a G13B. Once someone does that, THEN and ONLY then will I believe a G16 or G16/G13B head hybrid is better. The J-series will not match up to the G-series box. The other thing you should consider, is the adding of yet MORE weight to the front of your FWD car. Great for a straightline...but
PostPosted: Sat May 20, 2006 12:36 pm
Is the G16 block the same ast the G13B Block?? And will the Gti head bolt right on with no issues?
 Post subject: Re:
PostPosted: Mon Jan 14, 2013 11:45 pm
more hp yes, but not as much torque. and torque is what makes you go down the road. how about this test, take a 1.0 l and turbo it (about 100 hp), i will take a 672 cdi and turbo it (about 2000 hp) and you tell me which displacement makes more power. even without forced induction bone stock it runs 720 hp. That's over 7 times more power then a "smaller turbo engine"
no matter what you do to a engine, the bigger it is the more power it will make! hence the saying no replacement for displacement. let me know if you want that dumbed down so you can understand it.
