It is currently Fri Jan 19, 2018 4:50 am
PostPosted: Sat Apr 30, 2011 7:55 pm
anyone who has done a j18/20/23 into a swift
any mix and match between the swift sedan / esteem 1.8 that'll work or are they all custom?
08 Civic Wife's car
PostPosted: Mon May 02, 2011 2:27 pm
I'm doing a j20 into a samurai, and they are completely different animals entirely. My motor mounts are going to be custom. I do have the Aerio front motor mount still, I can't use it, don't need it. I'm interested in finding out if the j18 flywheel will work with a 1.6 clutch and bellhousing. Otherwise I am going to need a custom flywheel for my 2.0, since I'm using the 1.6 bellhousing.
PostPosted: Tue Jun 14, 2011 7:29 pm
no mix and match for the swift. the J series was never meant to fit in there, so you're on your own for the mounts. If you search you'll find a thread of a J swapped swift, it says that if you use the 1.6L swift stuff, you can use a lot of stock parts but you need to cut and box the right side frame rail to fit the engine.
Suzuki Gold Master Tech
PostPosted: Tue Jul 19, 2011 5:12 am
J-Series Samurai Engine Conversion
http://www.trailtough.com/index.php?pag ... &Itemid=53
http://members.cox.net/aftermarket4x4/2liter.html
