It is currently Wed Jan 24, 2018 5:11 am
PostPosted: Thu May 09, 2013 8:41 am
I'm rebuilding a engine that is a 1.6 Dohc conversion (all stock) got 106 hp at the wheel and would like to increase this with rebuild , heads getting worked crank and fly wheel lightned and balanced and I'm tethering with the idea to use the g13 piston with the g 16 rod and crank to bring up the compression ratio .ive searched the site and found the d series pistons are the go but just want to try something a bit different ,if anyone has any ideas or has done this please message me thanks kris .
PostPosted: Fri Aug 09, 2013 9:47 pm
Hi, if you use those pistons you are going 12.5 cr more or less, honda p29 pistons will raise to 14.0 cr what is to much but have been done allready
PostPosted: Fri Aug 09, 2013 10:06 pm
About P-29 pistons... viewtopic.php?f=4&t=56091. That was on the G13b block though
image_id: 22616
1993 Swift Gti
