It is currently Mon Feb 19, 2018 1:21 am
 Post subject: pistons question
PostPosted: Wed Jul 03, 2013 10:16 pm
I am looking at this set of pistons and rings for my g10 build, I already have the turbo rods on the way, what would these do to my compression ratio? I would like it to be a little higher, I will be going with the 1mm overbore. the pic shows a dished piston, but the listing says flat tops. they as of yet they havent called or emailed me back
http://www.ebay.com/itm/89-97-Suzuki-Sw ... f0&vxp=mtr
 Post subject: Re: pistons question
just noticed it doesn't look like those pistons use a circlip for the pins... darn
only seen ones that go up to .5mm oversize. not a big deal I guess, i just wanted 1mm over. how about these? come with npr rings.
http://www.ebay.com/itm/89-94-Suzuki-Sw ... 9d&vxp=mtr
there are some that come in 1mm, over, but they are for a g13ba, wrist piston is the right size, what would that do to my compression ratio? as long as it doesn't go down, I'm ok with it.
thanks in advance for all opinions
