It is currently Mon Jan 22, 2018 12:31 am
PostPosted: Thu Oct 24, 2013 9:32 am
Hello,
I'm selecting an upgrade kit for my G13B, but I need some help to validate my chooses and I count with your experience.
I will use a CatCams for camshafts, identical to 210/340 that almost everyone uses, and I already have them laying down on the shop.
For valves I'm thinking going to +1mm and I will use the Honda D16A6 for Exhaust and Honda D16Z6 for intake:
Ferrea
F1857P E 25 mm 5.5 mm 118.75 mm 4.35 mm 25º Flo. Stock size. Super Alloy
F1822P I 30 mm 5.48 mm 118.6 mm 1.9 mm 20º Super Flo. Stock size
Or
SuperTech
Supertech Forged Exhaust Valve Set for Honda Civic CRX Del Sol D15 D16 HEVN-1003
Supertech Forged Intake Valve Set for Honda Civic Del Sol Acura EL HIVN-1012
About pistons I will use the P29/PM7 with 76mm from Nippon Racing like this
http://www.ebay.com/itm/JDM-High-Compression-ZC-P29-Pistons-Civic-CRX-Si-D16-ZC-Rings-D16Y-STD-75mm-/181131925270?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a2c4dd716&vxp=mtr
1) I will need that you validate the valves and piston choices, secondly I will need the ARP main studs and ARP Head studs, where to source and part numbers are welcome?
2) I will need a 76mm piston copper gasket to reduce the compression and avoid problems with valve clearances and I need some information in how to calculate that and where to source them?
3) Where I can source racing main and rod bearings and and what I will need to complete the valve train?
4) What I will need customize (besides the valves seats and overbore the block) - I did not understood what I have to do to on the stock conrods to use the P29 pistons, any idea?
5) And about the valves length what I have ask to do exactly?
6) Does Stock ECU with Toms II Rally Chip or 210/340 chip are good enough, which best?
Regards,
Miguel
1992 MK3 Euro Swift GTI, Suzukird SS Exhaust header + freeflow SS exhaust + N1 Tip, Suzukird aluminum fuel rail + FPR, 60mm Nissan 200SX TB + K&N Air Filter, Reinforced OEM Clutch + Suzukird Short Shift + Aluminium Flywheel + Gripper 1.5 way LSD 30/70, Apex springs + Koni Sport Shock Absorvers + Wiechers Sport Upper Front Strut Bar + Upper RearStrut Bar + Below Front Strut Bar, Suzukird Underdrive Pulley, 15"x7" Antera Wheels + Bridgestone S03 195/50R15, Kevlar pads + SS Sloted rotors + SS hose kit
PostPosted: Thu Oct 24, 2013 11:41 am
I think you can find some of the parts you need on the Suzuki Racing Developpement site:
www.suzukird.com
I know they have ARP Main Studs and ARP Head Studs.
'94 Swift GT, Summer Beater.
'05 RAM 1500 5.7HEMI, Daily.
'01 Dodge Caravan, RIP.
'99 Mazda Protegé, RIP.
'92 Swift GT, SOLD.
'92 Swift GLX 4dr Sedan: SOLD.
'93 Metro, SOLD.
'86 Forsa GL, RIP.
PostPosted: Thu Oct 24, 2013 5:54 pm
Hi Bruno,
Thanks for the info, but the prices are too high on that site.
Do you have other recommendation?
http://www.suzukird.com
PostPosted: Thu Oct 24, 2013 11:05 pm
No, I don't... Sorry!
'92 Swift GT, SOLD.
'93 Metro, SOLD.
'86 Forsa GL, RIP.
