It is currently Fri Jan 19, 2018 3:17 pm
PostPosted: Fri Jan 24, 2014 3:07 pm
Is it possible for my G10A gearbox couple to the G13 or G15 engine?
PostPosted: Fri Mar 21, 2014 3:19 pm
The g10 and g13 gearboxes have the same bolt pattern, the g15 and g16 have a taller block and therefore a different bolt pattern than the smaller engines, specifically the top two bolts at the top of the bell housing, you can get adapter plates to fit the smaller gearbox onto the bigger engines but not the other way around.
Users browsing this forum: miniswift and 1 guest
