It is currently Mon Oct 16, 2017 10:23 pm
PostPosted: Thu May 27, 2004 1:34 pm
hi there.
I am currently working on a 1.3 to 1.6 conversion on my '95 Suzuki Swift GTi.
i've already fitted my 1.3 dohc head onto the g16a engine and it fits great.
but now i've got a problem to fit my 1.3 gti gearbox to the 1.6
i've modified het gear box so it fits to the 1.6 but now the axle from the gearbox to the wheel doesnt fit (the right one with the support bearing)
currently i'm using this suport bearing from a gti or shoult i use the bearing from the 1.6????
does anyone know who sells a conversion kit for 1.3 to 1.6 and its price??
excuse me for my typing and gramatical errors
PostPosted: Thu May 27, 2004 7:40 pm
The mad quebecer
The mad quebecer
None of the housings will bolt to the 1.6 block. You may be able to fit the 1.3 half-shaft housing with some milling on the mating surface. Howerver, this is only a band aid fix because only two bolts out of three will hold the bearing housing into place. It's prone to faillure under load or quick acceleration. Not a good idea to tear off a nice chunk off metal off of your block huh?
Okay, I may have a Custom housing drawn and cnc machined. How much are u willing to spend on that part?
PostPosted: Fri May 28, 2004 3:34 pm
SENSELESS GTI
Guest
Items
Posted: Sat Mar 01, 2003 3:08 pm Post subject: re
i have the G16A block and my gti transmission bolted straight to it no problems at all.
im from australia
how did this guy do it????
don't know...depends if my 1.3 gearbox will fit good??
PostPosted: Sun May 30, 2004 10:09 am
The mad quebecer
The mad quebecer
Yes it bolt straight, the upper bolts line up perfectly, so does the mainshaft. You need to modify the block to be able to bolt the two side bolts.
Note that he's not talking about the half-shaft housing.
PostPosted: Tue Jun 01, 2004 2:20 am
yes the upper bolts fits perfect i've seen that but now i've got a problem with the right axle and it's support bearing.
do i need the suport bearing of the 1.6 or gti?
can you explain what that half shaft house is??
and what do you think is the best solution for me?
PostPosted: Tue Jun 01, 2004 7:28 am
The mad quebecer
The mad quebecer
right axle support bearing = half shaft bearing housing
Just different names for the same thing. I explained what to do in the previous post.
PostPosted: Tue Jun 01, 2004 2:03 pm
what will this custom house cost me? and will my right axle support bearing fit into the gearbox??
or can i transfer the gears from 1.3 gti over to an 1.6 house?
PostPosted: Fri Sep 17, 2004 5:35 am
finally the job is done
the 1.6 is running great in my gti
still needs some mods, but that is gonna be alright
PostPosted: Sun Dec 11, 2005 5:12 am
hi my name is jim i am from greece i have modified my engine to g16a and i used the transmision from baleno 1.6 i don't have any problem is this correct. thanks.
PostPosted: Tue Aug 22, 2006 4:30 am
i to just finished the install to g13 box bolted on fine into my g16a but the starter isnt kinda working fine, its grinding or doesnt start... which starter did you guys use?? please help out...
thanks a ton
PostPosted: Tue Aug 22, 2006 5:22 am
jep, I had the same problem.
I solved this to rasp a bit off the starter housing and the gasket between the the starter and gearbox.
look at my site ---> 1.6 conversie ---> page 3, last 3 pics
PostPosted: Thu Mar 08, 2007 10:38 am
when i brought the idea to my mechanic of swapping the bottom half he told me that i'd have to get a G15 or G16 Gearbox housing and i could put the GTi 1.3 gears in it. but friends of mine had already done it and what they told me they did was, they machined new holes in the gearbox housing to mate with the block
The Greatest Drivers, The Greatest Machines, The Greatest Glory....
SUZUKI ... The Joy of Driving, The Thrill of Victory
