It is currently Sat Oct 21, 2017 12:53 am
PostPosted: Sun Dec 12, 2004 1:51 am
What do you guys think...Should i go with gsxr 600 or 750 throttle bodies?
The 600's are 36mm i believe and the 750's are 42mm. everyone's best opinions are needed. anyone who is running an itb or quad carb setup could you provide your specs...i've searched the entire board, but no clear answer to my question.
Thanks...
14.84 @ 93.89 with No ITB's, No standalone computer, No dog box, Stock MAF, Single TB and Street tires all in a complete mk2. not bad eh!
PostPosted: Sun Dec 12, 2004 4:13 am
Senior Member
Hmmm, look at it this way, compare your quad TB overall intake area against a single TB. The easy answer is this,
The equivalent single TB intake area of a quad TB is 2 X the diameter of one of its ports.
ie 36mm 600R TB's is equivalent to a 72mm single TB.
Its also more about the effect of the plenum tubes and that is not an exact science as it depends on Ve (Volumetric efficiency)and other modifications that have been done to the head.
Searches will not come up with any exact answers as there is no "exact" answer. It is a lot of trial and error.
If you want to know more, subscribe to this. http://www.eng-tips.com/viewthread.cfm?qid=93258
this is a forum with guru's on board.
Too much for me... (btw, I have bought a set of 600R quads and after the interminable wait for shipping, I'll tell you how it pans out...)
PostPosted: Mon Dec 13, 2004 4:43 pm
I bought GSX-R 750 with diameter 42 mm
Lander
Suzuki Swift Kit Car
 Post subject: 40 mm
PostPosted: Mon Dec 13, 2004 4:59 pm
I have a set of 40mm ITB's I will be running.
 Post subject: .....
PostPosted: Tue Dec 14, 2004 10:27 pm
Senior Member
Since TB's (not carbs) have no chokes, 36mm or bigger will be fine, A GTi port is about equal to a 36mm hole. My carbs (not TB's) are 40mm CV bike carbs from an R1 - you will certainly find this info elsewhere. GMC is running 36mm race carbs, also to be found elsewhere. Best thing about the CV carbs is that they have a constantly variable choke, meaning it adjusts itself to engine requirements, giving a broader spread of torque and more immediate low-down response.
A lot of the issue with the 36mm bike carbs is not the amount of air they can flow, but rather the fuel bowl size and/or the amount of fuel they flow.
 Post subject: Re: .....
PostPosted: Wed Dec 15, 2004 5:56 am
Hallo
Please, when you writed detail description of installing and setting your carbs? I have also on the way R1 carbs so I will be able to decide which way to go, ITB or carbs.
Lander
 Post subject: carbs
PostPosted: Wed Dec 15, 2004 10:29 am
hey lander
email "poruki" here on the forum. he has a set of bike carbs mounted on swift manifold with filters. he is gonna be selling them.
 Post subject: Re: carbs
PostPosted: Wed Dec 15, 2004 1:34 pm
Murr wrote:
hey lander
Sorry, I am not going to buy them because I have set of R1 2000 carbs on the way.
Lander
 Post subject: .....
PostPosted: Wed Dec 15, 2004 6:35 pm
Senior Member
Have a look in my personal gallery for pics. Also, in this same section, under 2000 R1 carbs.
