It is currently Thu Jan 18, 2018 4:52 am
PostPosted: Mon Mar 07, 2005 9:35 pm
just 4 fun i am going to put a 4 barrel carb on my 1.3L swift, what do you think will happen???
1991 swift GT and i only payed $50!!!
2004 nissan 350Z
PostPosted: Mon Mar 07, 2005 11:37 pm
bog. the smallest i have seen is a 390 holley. i put one on a 2.3 vega engine. the noise is cool but no power increase. and thats with a cam and header.
Dattman wrote:
PostPosted: Tue Mar 08, 2005 7:53 am
I've seen pictures of a 4-barrel on an old 1.5 liter Civic. The guy who did it says it's great. :?
Seems a bit excessive to me. :shock:
1992 Swift - Parts car (gone)
1991 Swift - Parts car (gone)
1990 Swift - Parts car
1997 Metro - Parts car (gone)
1993 Metro - Parts car
1989 Swift GTi - Parts car
1998 Metro - Parts car
 Post subject: .....
PostPosted: Tue Mar 08, 2005 4:51 pm
Senior Member
My only question would be.....Great - as compared to what?
 Post subject: Re: .....
PostPosted: Wed Mar 09, 2005 7:08 am
The stock two barrel, I guess. :?
 Post subject: ok
PostPosted: Fri Mar 11, 2005 1:48 pm
ok but will it make my air/fuel ratio go to rich and will my little 1.3 blok take it?
2004 nissan 350Z
PostPosted: Mon Mar 14, 2005 5:04 am
it depends on how you tune it,
the stock carb is a twin barrel down draught which is good enough, you are better of spending your time on other things such as playing around with the exhaust.
 Post subject: ok
PostPosted: Fri Mar 18, 2005 12:50 am
i alreddy have 2 1/2" BroSpeed exsast and K&N high flow air filter and am working on finding a good header replacement so i want to skreew around with the carb, i might add a 2 barrel first and if there are no problems then i will try a 4 barrel.
2004 nissan 350Z
PostPosted: Fri Mar 18, 2005 1:13 am
in truth you probably wont have enough vacuum to get the proper signal across the venturies!! you might run lean. also if you get a vacuum secondarys they will probably not open. :? :wink:
PostPosted: Mon Apr 18, 2005 2:51 pm
i have sedan 1.3L soch with (HKS sports muffler free flow) ,4point plugs BOSH,K&N air filter) im thinking to upgrade my engine CC around 1400cc to 1500cc wht u guys think will it be better or i have to change the coil ,plug wires and other basic thing .....
R A C E R 38
PostPosted: Mon Apr 18, 2005 4:37 pm
Get rid of those Bosch +4 sparkplugs and go back to your stock NGKs. Those Bosch plugs have been nothing but problems for other people.
PostPosted: Thu Jun 02, 2005 6:46 pm
ha ha ha wery bad :!:
