It is currently Wed Oct 18, 2017 3:46 pm
 Post subject: Conversion to carbs
PostPosted: Sun May 22, 2005 7:13 pm
Hi there,
I have a Suzuki Samurai that had the 1000cc engine, then that motor broke and i put there the engine from a swift gti.
I have some problems the direct injection, the fuel doesn't go to the injectors.
The gasoline pressure outside the gas tank is ok, on the engine too. I can't figure out where the problem is, i'm trying to solv this problem more than a year.
What I want to do is convert the engine to carbs. I need to know what type of induction manifold is used and where I can get one used or new, and what carbs can be used.
I have a friend who made that conversion, here it is the photo.
You laugh because i'm different...
I laugh because you're all the same
 Post subject: .....
PostPosted: Mon May 23, 2005 12:00 am
Senior Member
You can use either Webers or bike carbs. If you are doing a bike carb swap, you will need to custom make a manifold. If yousing Webers, there are some places around that can do you a manifold. Try going to ukswift site and talking to "Hamgar" about one.
