It is currently Thu Oct 19, 2017 10:49 am
PostPosted: Wed Jun 22, 2005 3:31 pm
Hi there
I've got a set of 4x40mm ITBs and want to run them on my Swift Gti (its a '89er ea, (in germany it's called "mk2 typ1")
what possibilities do exist to do so without the MAF sensor?
I've read here somewehre of changing over to MAP sensor, but I dunno what a MAP sensor is and where to mount?
Free Programmable ECU would be the only possibilitie to run the itbs openly without maf etc., right?
is megasquirt enough to do so?
it should be as cheap as possible...btw.
and what injector size and brand do you suggest in order to run 40mm quad-itbs?
thanxalot
Bösi outa Germany :D
PostPosted: Tue Oct 11, 2005 11:55 am
megasquirt woork well on itb...
PostPosted: Tue Oct 11, 2005 1:44 pm
A MAP or manifold absolute pressure sensor is a small box that can typically be mounted on the firewall and connected to the intake manifold using a vacuum line - for independent throttle bodies you might want to use some sort of "quad-T" fitting to connect all four throttle bodies to it - it may or may not be necessary.
PostPosted: Wed Oct 12, 2005 10:14 am
I am working on ITB with airbox and MAF together with stock ECU wich group A rally chip. It works. I have soo much power that I have slip on 3rd gear.
Lander
Suzuki Swift Kit Car
 Post subject: running ITB without MAF
PostPosted: Sun Feb 19, 2006 8:33 pm
It has been a while since anyone posted on this thread and I wanted to find out what progress has been made on using individual throtle bodies with the stock ECU or an aftermarket ECU.
Thank You
PostPosted: Mon Feb 20, 2006 12:23 am
Bargain basement
Thank You
What do you want to know? Aftermarket ECU is fine for me.
 Post subject: running ITBs without MAF
PostPosted: Mon Feb 20, 2006 11:15 am
I wanted to know if anyone had successfully swapped the individual throtle bodies from the Suzuki GSXR1300 on the Swift GTi? If someone had done it I wanted to find out how it was done. If it had been attempted but they were not successful I wanted to know what was the stumbling block. Whether they used the stock ECU or an aftermarket unit???
Thanks
Jorge
 Post subject: ITB!!!!
PostPosted: Sat Mar 04, 2006 12:04 am
Yes it can be done but the best way for succes its go for progammable ecu GusGTi hes a member from australia he got this kind of setup ITB with Haltec E6X he is pretty fast 14.2 in the 1/4 mile.
PostPosted: Fri Jun 23, 2006 8:11 am
check rospen's project.
http://members.iinet.net.au/~rospen/pro ... uadgti.asp
Lee, Singapore
PostPosted: Sun Jul 30, 2006 8:06 pm
leeye wrote:
This has been done quite a while ago. I think Ross is busy with other projects currently.
But on the subject. If you are running stock ECU split sec units could be used to convert the MAP sensor reading into the MAF expected signal.
Alternatively if using the aftermarket ECU like Gus or myself TPS reading should be enough for a basic (non closed-loop) operation.
