It is currently Sat Oct 21, 2017 7:06 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Fri Mar 24, 2006 7:51 am
Hi
I e-mailed you. Don't have pictures with me now but will add them at a later date.
The engine is fitted to a Mk 4 Escort which is used for rallying. The car is front wheel drive and I have mated the Swift engine to the Ford gearbox by modifying the Ford bellhousing.
Spec is as follows.
I currently don't have a soft copy of the engine maps - but I could probably get them from the rolling road guy that mapped the car.
Rgds
Ger
Engine Suzuki Swift Gti Bored to 1395 cc
Forged Arias Pistons (supplied by Bill Falkoner)
Fully ported Cylinder head
Bill Falkoner cams with solid lifters
New bearings all round
Mocal Oil cooler with stainless steel braided oil lines
Engine management
MBE 967E fully mappable ECU controlling fuel injection and ignition
42mm quad throttle bodies fitted to custom inlet manifold
Fitted with 8 injectors (only 4 in use at present)
132 BHP with flat torque curve from 3000 rpm.
Rev limit set to 7900 rpm
Twin Bosch fuel pumps separately switched
Malpassi adjustable fuel pressure regulator.
Exhaust 4-2-1 manifold & downpipes
2" single box system
Gearbox Ford BC FWD gearbox with modifed bellhousing to suit Suzuki engine
Quaife straight cut close ratio 5 speed synchro gearkit (4.54 final drive)
Quaife ATB limited slip differential
Helix competition paddle clutch
Quick shift kit fitted to gear lever
Custom lengthened driveshafts (made by Reco-Prop)
RS Turbo inner and outer CV joints
PostPosted: Mon May 08, 2006 9:17 am
Pictures added here - sorry about the quality - taken with a phone.
[/img]
PostPosted: Mon May 08, 2006 11:07 am
are u runnin the same radiator with the extra power? as im not sure on how my set up will work with the standard rad
tempo
PostPosted: Mon May 08, 2006 4:41 pm
I'm running a modified Mk4 Escort Rad. It's almost the full width of the car so a good bit wider than a swift rad. The modification was just to move the inlet and outlet to one side of the rad (and obviously block half the end tank on that side to force the water across the rad).
PostPosted: Mon May 08, 2006 4:42 pm
