It is currently Sun Feb 25, 2018 6:50 am
PostPosted: Sun Sep 11, 2005 11:42 am
Hi,
I bought a carb setup that had been fitted to a swift by the Boggs brothers in england.
I have now fitted the carbs. the fuel runs through an FPR to the carbs.
I'm wonderin if anybody has any diagrams of the carbs or a description of what all the ports etc are for.
The car turns over but doesnt fire. fuel is going into the carbs and there is a spark, but the plugs were dry when i removed them, so no fuel is going into the cylinders.
Just a bit stuck would do with some advice!
cheers,
ben
PostPosted: Sun Sep 11, 2005 4:38 pm
Hi,
Did you buy it from Ibrar?
If you did, then I have some info.
It is R1 carbs with mk1 inlet manifold modified to fit carbs.
Let me know if it is then and I can send you some diagram of R1 carbs.
Cheers
Atchi
 Post subject: .....
PostPosted: Sun Sep 11, 2005 5:03 pm
Senior Member
Are these the ones fitted to gsi's car? If so...check the afr's.
 Post subject: .
PostPosted: Sun Sep 11, 2005 5:04 pm
Senior Member
I found Yamaha bike dealers were also most helpful!
