It is currently Tue Oct 17, 2017 12:22 pm
 Post subject: cbr 1100 carbs
PostPosted: Thu Nov 10, 2005 1:36 pm
as the above says iv just fitted the cbr 1100 carbs. opted for the carbs as i aint a fan of all the electrical stuff that can go wrong (ecu etc). along with these i have a modified head, rally cams, janspeed manifold and full exhaust system. wen carbs are fully set up im hopin t get a power output done. what should i b expecting?
dug
PostPosted: Thu Nov 10, 2005 4:13 pm
depends on head work etc.. maybe 140 whp.. Someone on here said they had around 150/60 hp on dual 45's, I am not sure if it was whp or at the flywheel.. What is your guess?
Scott
You Just Gotta Beast It!!
PostPosted: Thu Nov 10, 2005 4:16 pm
Scott
Very doubtfull. Take it to a dyno an become disapointed.
 Post subject: .
PostPosted: Thu Nov 10, 2005 4:37 pm
Senior Member
Depending on cams (rally cams can mean anything) and headwork, etc, aim for around 140hp atf and you should be close. What size are the CBR carbs?
PostPosted: Thu Nov 10, 2005 6:36 pm
as far as im aware ther 2mm bigger than r1 carbs but not sure on exact size. i no ther from an 1100 cbr. rally cams are from tighe. its the 952 cam that i hav. i hope i do get 140hp. thatd do me jus fine
dug
PostPosted: Mon Feb 20, 2006 7:59 am
It's been a few months since you posted this. How's it going????
GTi MOTORSPORT
Catch us at the local rallies and the Autocross
PostPosted: Wed Feb 22, 2006 3:08 pm
its in the final stages of fine tuning now. but its lookn good. il b sure to post pics and vids when its done.
tempo
PostPosted: Thu Aug 24, 2006 11:54 am
update on the project!!!!
well its inally done and it goes likw a fukin train!!! im reall happy with the results. the 952 rally cams sure do kick in at bout 4k rpm.
tempo
PostPosted: Fri Aug 25, 2006 12:25 pm
Come on Dug,
Give us more info, man!
What setup ..well, advance curve did you do to dizzy?
Did you fit airbox?
What size exhaust?
Spill your beans....!!!
Cheers
Atchi
PostPosted: Thu Sep 14, 2006 5:22 pm
no airbox as of yet. i hav a modified cylinder head, tighe 952 rally cams, cbr1100 carbs, janspeed manifold, 2inch exhaust i think. i have no idea on degrees of advance as boggs bros sorted it but i know i never needed the mechanical dizzy. goes very well. il try get a vid on here wen i can get me digital camera goin.
tempo
