It is currently Sat Feb 17, 2018 8:17 pm
 Post subject: Turbo carb
PostPosted: Mon Nov 21, 2005 2:29 pm
Just wondering if anyone has gone turbo with a carb? I plan on doing a draw though setup on a 1.0 and was wondreing how big of carb to use?
PostPosted: Mon Nov 21, 2005 2:55 pm
You mean like this??
Depending on the turbo size, I would say you should start with a stged 2 barrell, around 32/36, similar to those used on Chevettes, 2.2 Dodges, and Mustang 2.3's.[/i]
PostPosted: Mon Nov 21, 2005 10:05 pm
yeah thats kinda what I hab in mind. I have a RHB5 VJ5 that I plan on using and plan on doing an air to water intercooler.
PostPosted: Tue Nov 22, 2005 9:06 am
Does that turbo have a mechanical seal?
I think you'll need it for a drawthrough
 Post subject: .
PostPosted: Tue Nov 22, 2005 5:17 pm
Senior Member
32/36 was also used here on 2.0 Ford Escorts...sometimes known also as the Pinto engine. Just as an aside. Neat pics above.
 Post subject: Turbo setup
PostPosted: Sun Jan 01, 2006 6:33 pm
i have a 1300 cc carb setup on my swift for about 2 years
i am using a standard carb, with pressureize shaft
using a IHI turbo from a 323 madza
a carb box on the carb
2.5 exhaust system
msd 6BTM
blaster ss coil
msd plug wires 8mm
Front mount intercooler
customize Gti gear box
ACT pressure plate
7lbs flywheel
plus more
i drive around every day on 10 psi and race at 15 psi
PostPosted: Wed Jan 18, 2006 1:00 am
banned
nice..
how much power u putting down bro ?
PostPosted: Wed Jan 18, 2006 8:12 am
it was dyno at 15psi and giving me 195hp to the ground using the IHI turbo
RALLY, IMPORT CARS
 Post subject: pic of the engine
PostPosted: Wed Jan 18, 2006 8:16 am
pic of the engine
http://www.cardomain.com/ride/2233689
RALLY, IMPORT CARS
