It is currently Tue Oct 17, 2017 3:59 am
 Post subject: R1 Carbs Info
PostPosted: Thu Feb 02, 2006 8:40 am
Hi,
First of all let me apologise that I don't own a Swift :oops: but I need some help for my old skool alfa and you guys seem knowledgeable with regards to motorbike carbs on cars.
Basically I have a set of R1 carbs to use but need to know whats what on them!! ie, what fuel & air connections do what? How to separate them (without breaking anything!) Does anyone have a diagram or anything that might help? or perhaps some websites that do?
Also, I noticed inside the carbs in front of the butterfly's is like a piece of plastic, kinda like another butterfly, any idea what this is for?
Any help would be most appreciated.
Cheers,
Jaty.
PostPosted: Thu Feb 02, 2006 3:09 pm
Hi,
I have diagram and all the detail you need from Haynes book for Yamaha R1 bikes.
I will need to have bit more time for me to scan it in then I will send you as a pdf format if you would like.
Or I can send you by post.
I am fitting R1 carbs to G13B Gti engine and into Mini.
So, I can help you little.
There are more knowledgeable ppl on this forum, too.
Good luck and speak to you soon.
Cheers
Atchi
PostPosted: Fri Feb 03, 2006 4:36 am
Hi Atchi,
Cheers that would be most helpful, pdf format would be great and I'll just print it out (at work obviously!!).
Will send you a pm with my email.
No problem on the time, I'm in no great rush.
I've got an Alfasud that I know have a 1.7 16v engine from an alfa 33, which is the engine I'll be running the carbs on hopefully! Only thing is I have to split the carbs into 2 pairs as the engine is a flat four. Shouldn't be a problem, just makes it bit more of a challenge :lol:
Cheers again,
Jaty.
PostPosted: Sun Feb 05, 2006 5:11 pm
Jaty,
I got it scanned but it is 35MB.
I will try and make it smaller without losing quality.
Otherwise, I have to send it to you by post.
Let me know your thought.
Cheers
Atchi
PostPosted: Mon Feb 06, 2006 4:25 am
Atchi,
Cheers for that, don't know whats best, could you zip the files?
If not then cool, just send me in the post, i don't mind either way, whatever is easier for you really as you've been most helpful.
If your gonna post them, let me know and I'll pm you my address.
Cheers,
Jaty.
PostPosted: Fri Sep 08, 2006 11:42 am
Atchi,
Is it possible to host the PDF files on a server? I'm also busy with R1 carbs on a GTI engine, but I haven't a clue how to connect the carb.
Mark
Mini owner with a speed addiction.
Still under construction....
PostPosted: Fri Sep 08, 2006 12:31 pm
Hi Mark,
Give me your e-mail address by pm and I will zipped up and send it to you.... Well I tried but it only got to 34Mb.
I can send you one by one...lol
Cheers
Atchi
PostPosted: Fri Mar 16, 2007 10:10 pm
hey atchi,
could you also email me the haynes book for r1 carbs.. my email is on the site..
thank you
slash
PostPosted: Sun Mar 25, 2007 2:50 pm
Hi,
Did you get my e-mail I sent you?
I have them in pdf files now if anyone else want them.
Cheers
Atchi
PostPosted: Mon Mar 26, 2007 1:14 pm
i used 2 have an alfa 33 clover leaf permenent 4 the boxer sounded beauitfull but it didnt have enuf power 2 get the rear out so it just understeerd i even tryd the scandinavian flick wiv no joy it woz standard tho bout 140 bhp
but sum old granny ended up driving her rusty old mini in the n/s passenger door on a roundabout i woz well gutted but i did end up gettin twice wot i payd for it from the insurance thats when i got me swift
gary
