It is currently Tue Jan 23, 2018 9:56 pm
PostPosted: Thu Feb 16, 2006 6:39 am
Dear my friends all over the world, I want to share my photograph doing swap engine from SOHC 8v to DOHC with twin carb.
All comment and question are wellcome, I'm waiting for your comment.
Spec :
- 1.3 DOHC non JDM from junkyard
- SOHC ignition distributor
- custom intake manifold
- twin KEIHIN carb from Honda D series engine
- 9 mm multicore spark plug
- BOSCH super Coil 40K volt
- Splitfire SF 426c
- 15" compomotive rally rims with 195/50/15 tyre
PostPosted: Thu Feb 16, 2006 6:48 am
Next picture
PostPosted: Thu Feb 16, 2006 7:58 am
Closer look to the engine
PostPosted: Thu Feb 16, 2006 12:48 pm
very cool!! wheels look very good. welcome to the forum. :D
dont forget to clean the air!! :wink:
Dattman wrote:
PostPosted: Fri Feb 17, 2006 3:16 am
Next photograph
PostPosted: Wed Mar 15, 2006 1:09 am
Looks very familiar to me...
"Kayaknya pernah lihat di tabloid otomotif neh :P"
gabung juga kesini ya om => http://groups.yahoo.com/group/suzukiamenity
PostPosted: Wed Mar 15, 2006 1:41 am
Nice work!
1974 Filipino wife
1987 Chevy Sprint Turbo
1989 Honda Civic (JRSC)
2008 Honda Civic Hybrid
2009 Campagna T-REX
2009 Dahon Vitesse P18
2010 Mercedes G55
2010 Toyota Prius (yup a prius)
2010 Nissan GT-R
PostPosted: Wed Aug 02, 2006 6:46 pm
That's look exacly the same as my swift except mine using 1.3 SOHC with twin keihin. I have few questions to ask you. How was your performance with that twin keihin? And also how do you set the air/fuel mixtures with that keihin? Do you know how to tune that twin keihin? Wokie..
PostPosted: Tue Aug 15, 2006 12:18 pm
I feel great about fuel consumption, its better than Weber ( i got Weber installed before).
Weber => 5 to 6 Km/ Litre
Better response from mid to peak RPM ( I tried to 8500 rpm and then twisted the con rod )
Keihin => 8 to 10 Km/ Litre ( using 150 or 160 main jet )
Better response from bottom to midle RPM. it works fine until 6500 rpm
( affraid to make it twisted again. not try above it )
Tuning is same with weber, mine are in factory default. only try swapping main jet until got better AFR ( looks from spark plug )
