It is currently Sat Jan 20, 2018 4:36 pm
 Post subject: help on a G16A carb
PostPosted: Sat Mar 18, 2006 6:55 pm
Hello everyone, this is my first post here...
Guys im in some urgent need for the vacuum pipe diagram and how to carb my rides carb. I have a chevy swift sedan with a 1.6L 16 valve sohc engine (If im not wrong its the G16A engine)... but every mechanic that has tried to carb the engine will just screw it up more, others will just refuse to work on it, everyone fears that carb :(
Im missing about 4 vacuum pipes and the other ones are way wrong.
Im not an expert on car engines ... but I know my way around and i want to start fixing/tweaking my ride myself.
Oh and something else im guessing is carb-related .. early in the morning when the car is cold and I turn it on it will just keep stalling like 10+ times until it gets a little warm, and I cant even push the gas pedal for like 10more minutes or else it will just stall again.. what to do ?
Guys I will greatly appreciate your help. Im in a desperate situation trying to fix my carb.. thank you!
PostPosted: Tue May 23, 2006 8:03 am
Toyota-Tercel in the same way swift G16A carb. OK.
I send you solution.
good luck... :)
Attention!!!
http://repairnet.aircare.ca/documentati ... tercel.pdf
