It is currently Sun Oct 22, 2017 3:46 am
 Post subject: im stuck
PostPosted: Mon May 01, 2006 7:55 am
hey guys as most of you will know by now i hav installed cr 1100 carbs but im stuck on makin it work right. i cant find a mk1 gti dizzy anywhere so what other route can i go down to get this baby workin correct?? i see there are lots off ppl sayin do this and do that but which is the correct way??? please help guys as my car is stuck on the drive doing nothing!!!
cheers tempo
 Post subject: .
PostPosted: Mon May 01, 2006 4:58 pm
Senior Member
PM ellpee. Tell him Lee said hi. He should be able to help you out with a dizzy.
PostPosted: Tue May 02, 2006 2:10 am
Senior Member
he already has, I can;t find my spare..... I think I may have tossed it....
PostPosted: Tue May 02, 2006 3:41 am
I'm pretty certain I've read elsewhere on this forum that you can use the 8v sohc carbie distributor, of course you will need to get it recurved but should be a lot easier to find than a mk1gti dizzy.
I might be doing the same thing in a few months, unless I can find a couple of grand for an aftermarket computer I might be pulling my 40mm dellorto's off my datto to use on my swift race car... let us know how you get on.
P.S. have you talked to Dara ( Mad for Tar) he had a spare mk1gti dizzy about a year ago...
PostPosted: Tue May 02, 2006 9:06 am
thanks guys. iv spoken to bdgracia about the ignition unit he used. he says its very good and good for getting the most from the carbs. any1 else hav views on this ignition unit~??
cheers tempo
PostPosted: Tue May 02, 2006 10:26 am
Hi Tempo,
If you ask me nicely, I can sell one of my spare....
I won't need mine for while and I have whole mk1 I drive....
I should't be greedy and have 3....
Let me know if you are inetrested.
Atchi
 Post subject: .
PostPosted: Tue May 02, 2006 4:50 pm
Senior Member
Atchi I thought you'd sold all yours, or I'd have headed Duggie your way! As for the ignition unit, if Bolivar recommended it, then it works.
PostPosted: Sun May 14, 2006 12:23 pm
Hello,
Maybe I can help you, Have you read my post with subject (SOHC 8v to DOHC with twin keihin carb ) ?
In here (Jakarta, Indonesia) SOHC 8v (carburetor) dizzy with single/ double port vacuum advancer (refurbished) sell about $ 85.
If you looking for brand new dizzy, it cost twice or more than refurbished.
PM me if you need more help.
PostPosted: Mon May 15, 2006 11:23 am
thanks for the help duys. i now have the mk1 gti dizzy. atchi i owe you big time!!!!!!!!!!! cheers again.
tempo
