It is currently Fri Oct 20, 2017 3:13 pm
PostPosted: Tue May 30, 2006 10:49 pm
i was wondering if i could cange my carb and keep my original intake. it is a 1988 1.0. what all carbs will work?
PostPosted: Fri Jun 02, 2006 11:37 pm
your pretty well screwed
you can use a jap carb that is
not controled by the ECM
Aussy had them
if you need a carb try Tbirdscott he might have a good one
--------------------------------------------------------------------JV&S
PostPosted: Sat Jun 03, 2006 8:15 pm
i was wondering if i could use an aftermarket 2bbl if i made an adapter. ive seen some smaller cfm holleys at work.
PostPosted: Sun Jun 04, 2006 1:39 pm
I think the weber downdrafts are close in boltpattern. I haven't compared them, so don't take it as a fact though. On my '93 1.0, I made an adapter out of steel and put an old rochester 2SE on it. I had to hog out the plenum big time, change the distributor, and mess with the jetting, but it really didn't help alot. I think more power is available in the heads, cam, and exhaust, personally.
