It is currently Thu Oct 19, 2017 2:32 pm
 Post subject: carbs and offroading
PostPosted: Thu Jul 06, 2006 11:03 pm
I'm building a rockbuggy and was planning to use a G13B motor with some sort of sidedraft carb. not sure which one would be least likely to flood in some off camber angles. any suggestions?
 Post subject: Re: carbs and offroading
PostPosted: Fri Jul 07, 2006 9:52 am
fuel injection doesnt flood at any angle 8)
Dattman wrote:
PostPosted: Fri Jul 07, 2006 9:56 am
thanx but I want something with simplicity, I've had too many fuel injection woes in the past when I hit the trail. it may be my only option if I can't find a carb to suit my needs.
PostPosted: Thu Jul 13, 2006 9:30 am
Holley is the only maker that I know of that makes a carb that is built to be driven off road!
I had an upgrded weber 2 bbl carb on my samurai and I never had a prob with it not working even at bad angles!!
I beat the hell outa my sami and she never once stalled out because of the position she was in!!
Try that one!
http://www.22re.com/main/toy/weberdist.htm
I have seen them on ebay for around $250 to $350
accent1
Pres of http://www.tunerunlimited.net
90 Geo Metro
1.0 3cyl
air filter upgrade
MSD coil
Pilot steering wheel
Sunpro Tach
more to come!!!!
PostPosted: Wed Sep 06, 2006 1:28 am
I think your best bet would be to stick with the original Suzuki carb. G13A engine is also used for the SJ413 4X4 and I haven't heard any complaints about the carburetor so far.
I only have personal experience with an SJ410 and the engine keeps chucking away happily even after tipping the car over on its side (yes, I've done it at a trial competition :oops: ) as long as there's enough fuel in the tank to keep the fuel pump happy.
Yield to temptation; it may not pass your way again.
1988 Suzuki Swift 1.3 GLS
PostPosted: Tue Dec 19, 2006 4:22 pm
You could do a webber carb swap. It's pretty common for people to do on samurais. What I want to do on my samurai is a propane conversion kit from http://www.gotpropane.com Propane is a lot simpler setup than fuel injection and runs at any angle. IMO it is a hell of a lot better than a carb.
Another option is a mechanical fuel injection (my-fi) setup from http://www.zuksoffroad.com I've only heard good things about that system.
Here are a couple of sites to check out.
http://www.zukikrawlers.com
http://bbs.zuwharrie.com/
http://www.pirate4x4.com/forum
1987 Suzuki Samurai 1.3 g13a 4x4, getting toyota axles soon!
1998 Chevy Blazer 4.3l 4x4
