It is currently Tue Oct 17, 2017 12:11 am
 Post subject: CARB CONVERSIONS
PostPosted: Thu Feb 15, 2007 5:43 am
Just wondering wot exactly is required to do a carb conversion to a 1990 swift gti.
I know i'll need the carbs and i got some 1 to make me a manifold. but wot else?
PostPosted: Thu Feb 15, 2007 7:46 am
You would need a low pressure fuel pump, and a mk1 distributor aswell as these were not ecu controlled
PostPosted: Thu Feb 15, 2007 11:09 am
no need for a mk1 dizzy. mine is running fine with the mk2 dizzy. also just get a low pressure fuel regulator. if your interested i am trying to sell my cbr 1100 carb set up. if ur interested give me a bell
tempo
PostPosted: Fri Feb 16, 2007 5:20 am
What is included in your set up and how much do you want for it.
cheers
chris
PostPosted: Fri Feb 16, 2007 8:00 am
well i have cbr 1100 quad carbs and the manifold to fit the gti head. id like 150 plus postage. ive already got a buyer for the head and exhaust manifold tho. if your interested do you mind waiting as its all stil fitted on my car and im currently finishing my turbo set up. is that ok??
tempo
 Post subject: carbs
PostPosted: Fri Feb 16, 2007 8:51 am
is the manifold cast or al. wot was the head and ex mani you had?
PostPosted: Fri Feb 16, 2007 1:04 pm
i stil have it all fitted on my car. the head has a race skim which means a higher compression of 11.1. the exhaust manifold is a janspeed 4-1. the carb manifold is made from aluminium.
tempo
PostPosted: Fri Feb 16, 2007 9:43 pm
any chance we can see some pics?
Lee, Singapore
PostPosted: Sun Feb 18, 2007 11:50 am
If you want to fast with carbs you will need a good timing computer. With the MK2 or MK3 distributor is not possible. The best will be a Electromotive crank trigger ignition.
For carbs I have a chadil manifold with a pair of weber 45 dcoe carbs.
For fuel the best pump is a carter with no regulator. The reason is the carbs don't like high pressure but the need high volume. With a regulator you will control the pressure but not the volume.
I hope this works,
Bolivar
PS: You can see pics of my engine in http://photos.yahoo.com/bdgracia
PostPosted: Sun Feb 18, 2007 3:49 pm
so your saying that i could gain more with my carb set up?!!! well its too late now but id liked to have seen what they really performed like. i thort they wor awesome anyway but more would have been great. the standard dizzy seemed to work fine for me tho but i personally think buying an ignition computer for setting the carbs up is a waste as you may aswell go for quad t/b and buy an upgrade ecu. then you can always tune further this way. just my opinion.
tempo
 Post subject: Re: CARB CONVERSIONS
PostPosted: Tue Jun 10, 2008 8:35 am
Ok, been reading this thread & couple questions came to mind.
I have a project currently working on, the engine i'm using is the 8 valve G16.
Bike Carbs are my choice, in terms of intake system, but i'm not final on the head i'm using. I have no problem porting the 8vlave head, although needless to say, the GTi's head would've been a better choice.
couple members above posted that using the older MK1 distributor could work, does this mean i can use that dist. & run bike carbs straight on the GTi head without the use of the ECU ?
The Greatest Drivers, The Greatest Machines, The Greatest Glory....
SUZUKI ... The Joy of Driving, The Thrill of Victory
PostPosted: Tue Jun 10, 2008 4:20 pm
Hi,
I'm not sure it will work straight away but it will do the job.
Mk1 has mechanical and vacume advance mechanisms so that you will have correct advance curve for mk1 Gti. For mk1 ECU only controls injection.
For mk2, ECU control injection as well as advance curves. So you might get check light comes on all the time.
I hope you can find one of mk1 Gti dizzy. In UK, they are getting very rare.
Cheers
Atchi
PostPosted: Tue Feb 17, 2009 11:38 pm
bump! :)
Last edited by christiancox on Wed Aug 19, 2009 12:48 am, edited 2 times in total.
PostPosted: Fri Mar 20, 2009 9:29 am
If anyone wants to know how to wire in the Vacum advance cetrifugal for a 88-91 3_cylinder G-10 engine. I found a website for G-10 conversions in Ultralite (Aircraft) & the owner made it simple. Two wires 1+ & 1- (The POS just needs a power source -I would wire in auxillary) & (NEG- straight to the NEG on the coil ) When the field collapses you get spark and the engine curve is more less running on vacum . Otherwise you can use an Electromotive setup -Buy it for a 6 cylinder and ground off the the second connectors (they run (A-B-C) (A-B-C) (A-B-C) and your timing is 1-3-2 . Its in the manual ! :buzz:
PostPosted: Mon Mar 23, 2009 10:32 pm
You don't necessarily need a timing computer if you have your Mk1 dizzy recurved to suit your engine mods.
cron
