It is currently Sun Jan 21, 2018 2:58 pm
 Post subject: R1 carbs enough??
PostPosted: Wed Feb 21, 2007 10:22 am
Hey all,
I am planning to put 00-01 Mikuni R1 carbs to my swift.. just wanted to know whether it would suffice for the engine specs am running..
Am running a ported,polished head with high lift camshafts. Also running a G16B block with 77mm pistons.. Guess thats bout it.. The engine generates insane vacuum.. so just wanted to know if these carbs will work fine..
Thanks a lot
Slash
PostPosted: Wed Feb 21, 2007 12:08 pm
Hi,
Air volume wise, I'm sure it will be fine.
R1 has 4x40mm are and you can compare to what you have.
I think you might need to drill jet bigger to get more fuel.
Cheers
Atchi
 Post subject: hey
PostPosted: Thu Feb 22, 2007 10:05 am
Hey atchi,
I was just bothered about the airwise volume.. The driling is no problem.. I can get jets for it here.. Thanks a lot for the info
Slash
