It is currently Sun Oct 22, 2017 12:59 am
 Post subject: Advice on ITB setup
PostPosted: Wed Aug 08, 2007 7:29 pm
Hi guys, I wanted to make a new setup for my car.
- ITB's from a suzuki GSXR 750/1000
- Megasquirt Engine Management
- 2 Inch pressure bent exhaust system
- Magneflow Muffler
I just ran a 15,824 sec on the 1/4 mile with minor mods
- K&N filter
- Magnecor 8,5 mm wires
- Msd blaster 2 Coil
- Single Underdrivepulley
I was wondering what u guys reccomend on the ITB setup and wanted to drop the 1/4 mile time, someone said I could maybe run high 14's, what do you guys think?
15,824 sec at 86.2 MPH With only minor mods, K&N Filter, Underdrive Pulley, 8,5 mm Magnecor Wires and MSD 2 Blaster Coil
 Post subject: Re: Advice on ITB setup
PostPosted: Wed Aug 22, 2007 4:50 pm
- Magneflow Muffler
- K&N filter
Hi
What do you want exactly on the ITB's??
A filter or so?
Anyway,why take the ITB's??
Just mount some faster but not too wild cams,wich give you more NM and install a computer wich you can program (or chiptune the orginal) and you have more HP and more NM,and its cheaper. ;)
Swift GTi running @ 0.8bar
http://www.cardomain.com/ride/311033
http://www.suzimaniacs.com/phpBB2/viewt ... sc&start=0
PostPosted: Thu Aug 23, 2007 4:55 am
Hi,
I have read in some magazine that by fitting bike quad-carbs.
It will increase performance dramatically.
They even commented that by doing so, it is like fitting aftermarket ECU without a laptop.
I think it will be same for ITBs.
It will flow more air than single TB.
If you get right setup, it will come with a throttle position sensor.
It will sticll cost a lot of money to set up thought, IMO.
I'm still building my R1 carb setup and hopefull when I finish my house, I can start again.
I think Oz had his mk1 with R1 carbs with camshaft..etc to produce 30% more power from stock.
So, it must works well!
cheers
Atchi
PostPosted: Fri Aug 24, 2007 6:32 am
True,but thats not only becouse of the ITB's. :wink:
The wilder/faster cams can give you allready a 20/25hp improvement.
Depend on how wild they are offcourse.
I had no HP improvement with the quad carbs.
So i am not that positive of mounting ITB's for HP improvement.
PostPosted: Sun Aug 26, 2007 5:19 pm
can the Levin ITB's work on the GTi head? i've heard persons say it but i've never gotten the full details....
The Greatest Drivers, The Greatest Machines, The Greatest Glory....
SUZUKI ... The Joy of Driving, The Thrill of Victory
PostPosted: Mon Aug 27, 2007 11:20 pm
They will work, but you will need to modify them quite a bit to get them to fit. The spacings are all wrong and would need to be cut and shut to make fit.
PostPosted: Wed Mar 19, 2008 6:33 pm
Might come in handy. (copy paste in address bar)
http://www.my-acoustic.com/Car/vacuum/4 ... vacuum.htm
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Thu Mar 20, 2008 2:52 am
Senior Member
The levin itbs and manifold are a very close fit (if it is the AE101 inlet manifold) I fashioned a 25 mm plate of alloy into an adaptor, it took a little of aligning but it wasn;t an huge engineering job.
PostPosted: Thu Mar 20, 2008 3:16 am
ITB's by themselves will make a small difference, well in my case they did, but when used WITH more aggressive cams will make a much bigger difference than cams alone, plus they sound awesome :yeahyeah not sure I would use the Levin ITB's as the smallest ones are 42mm which is a little too big for a little engine like ours, better throttle response by using something smaller like 38mm ITBs off gsxr's etc.
 Post subject: Re:
PostPosted: Fri Mar 21, 2008 10:42 pm
how difficult is it to fabricate itb's usuing gsx-r carbs ?
PostPosted: Sun Mar 23, 2008 2:42 am
GSXR throttle bodies are the easiest to use, I'm using CBR900 ITB's and will probably make another set using gsxr itb's as it's easier to mount a plenum on using silicon couplers, also the gsxr itbs have the cable pulley wheel thingy on the end so you can replace it with your swift one to get the correct leverage ratio on your pedal, unlike my cbr itb's which I had to shorten the pedal to change the cable pull ratio.
The manifold it self requires a bit of work, you will need either 10 or 12mm plate alloy, either get it water cut or use a jigsaw for the outside and then die grind the port, you will need alloy tubing with an ID of 34mm and some mandrels to shape the runners as it goes from round 38/40mm ID on the itb's to 34mm oval ports on the flange/head, carefully crushing one end of the runner in a vice is ok for the flange, using a mandrel you will need to flare the other end of the runner to match the throttle body, then you can use silicon couplers and hose clamps to fit the itb's to the manifold.
When you tig the runners to the flange you will find the heat distorts the flange, it's easy enough to straighten it up using a hammer and a vice, 10mm plate warps quite a lot but is much easier to cut than 12mm.
There is a how -to on redlinegti by sk4wd on fitting gsxr itb's to a swift, it's worth a look although the only thing I suggest is make sure your plenum doesn't have any flat sides.
If it sounds too hard then I do have a very good fabricator :wink:
